How to get rid of 15 mb volume
I tried to install an application called Feedreader using these instructions:
git clone --recursive https://github.com/39aldo39/FeedReader
cd ./FeedReader
meson build
sudo ninja -C build install
the install ran into an error and I aborted the process. Now I have this 15 mb virtual drive that I can’t seem to get rid of. Can anyone help me get rid of it?
Screenshot from 2021-10-26 12-29-59
It could be a loop device.
Have you tried rebooting? That usually helps when I have “rogue” devices in my device list.
Ah I just tried rebooting and it did correct the problem, thanks!
Why not install feedreader from the AUR (Arch User Repository)? What’s so exiting about 39aldo39’s fork? If it is that special, then modify the PKGBUILD.
I didn’t see it on AUR, I would have preferred to get it from there
However, you do now, right? :wink:
pamac search feedreader
