Hi, where are the settings to allow anbox and apps inside of it to share the internet connection with the desktop? the “/lib//systemd/network/anbox” files that come when installing anbox and the dkms modules don’t appear to have done anything…
Ah…But is systemd-networkd going to break other networking?
Probably, so I wouldn’t install it. It’s not quite as user-friendly as Netiworkmanager. I would use the latter approach.
