Yep of course, the following is the full output:
$ sudo sensors-detect
[sudo] shore 的密码:
对不起,请重试。
[sudo] shore 的密码:
# sensors-detect version 3.6.0
# System: LENOVO 82B6 [Lenovo Legion R7000 2020] (laptop)
# Board: LENOVO LNVNB161216
# Kernel: 5.8.6-1-MANJARO x86_64
# Processor: AMD Ryzen 7 4800H with Radeon Graphics (23/96/1)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): YES
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595... No
VIA VT82C686 Integrated Sensors... No
VIA VT8231 Integrated Sensors... No
AMD K8 thermal sensors... No
AMD Family 10h thermal sensors... No
AMD Family 11h thermal sensors... No
AMD Family 12h and 14h thermal sensors... No
AMD Family 15h thermal sensors... No
AMD Family 16h thermal sensors... No
AMD Family 17h thermal sensors... No
AMD Family 15h power sensors... No
AMD Family 16h power sensors... No
Hygon Family 18h thermal sensors... No
Intel digital thermal sensor... No
Intel AMB FB-DIMM thermal sensor... No
Intel 5500/5520/X58 thermal sensor... No
VIA C7 thermal sensor... No
VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): YES
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'... No
Trying family `SMSC'... No
Trying family `VIA/Winbond/Nuvoton/Fintek'... No
Trying family `ITE'... No
Probing for Super-I/O at 0x4e/0x4f
Trying family `National Semiconductor/ITE'... Yes
Found unknown chip with ID 0x8227
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): YES
Probing for `National Semiconductor LM78' at 0x290... No
Probing for `National Semiconductor LM79' at 0x290... No
Probing for `Winbond W83781D' at 0x290... No
Probing for `Winbond W83782D' at 0x290... No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): YES
Using driver `i2c-piix4' for device 0000:00:14.0: AMD KERNCZ SMBus
Module i2c-dev loaded successfully.
Next adapter: Synopsys DesignWare I2C adapter (i2c-0)
Do you want to scan it? (YES/no/selectively): YES
Adapter doesn't support all probing functions.
Some addresses won't be probed.
Next adapter: SMBus PIIX4 adapter port 0 at 0b00 (i2c-1)
Client found at address 0x50
Probing for `Analog Devices ADM1033'... No
Probing for `Analog Devices ADM1034'... No
Probing for `SPD EEPROM'... Yes
(confidence 8, not a hardware monitoring chip)
Probing for `EDID EEPROM'... No
Client found at address 0x52
Next adapter: SMBus PIIX4 adapter port 2 at 0b00 (i2c-2)
Next adapter: SMBus PIIX4 adapter port 1 at 0b20 (i2c-3)
Client found at address 0x18
Probing for `Analog Devices ADM1021'... No
Probing for `Analog Devices ADM1021A/ADM1023'... No
Probing for `Maxim MAX1617'... No
Probing for `Maxim MAX1617A'... No
Probing for `Maxim MAX1668'... No
Probing for `Maxim MAX1805'... No
Probing for `Maxim MAX1989'... No
Probing for `Maxim MAX6655/MAX6656'... No
Probing for `TI THMC10'... No
Probing for `National Semiconductor LM84'... No
Probing for `Genesys Logic GL523SM'... No
Probing for `Onsemi MC1066'... No
Probing for `Maxim MAX1618'... No
Probing for `Maxim MAX1619'... No
Probing for `National Semiconductor LM82/LM83'... No
Probing for `Maxim MAX6654'... No
Probing for `Maxim MAX6690'... No
Probing for `Maxim MAX6680/MAX6681'... No
Probing for `Maxim MAX6695/MAX6696'... No
Probing for `Texas Instruments TMP400'... No
Probing for `Texas Instruments AMC6821'... No
Probing for `National Semiconductor LM95233'... No
Probing for `National Semiconductor LM95234'... No
Probing for `National Semiconductor LM95235'... No
Probing for `National Semiconductor LM95245'... No
Probing for `National Semiconductor LM64'... No
Probing for `SMSC EMC1047'... No
Probing for `SMSC EMC1402'... No
Probing for `SMSC EMC1403'... No
Probing for `SMSC EMC1404'... No
Probing for `ST STTS424'... No
Probing for `ST STTS424E'... No
Probing for `ST STTS2002'... No
Probing for `ST STTS3000'... No
Probing for `NXP SE97/SE97B'... No
Probing for `NXP SE98'... No
Probing for `Analog Devices ADT7408'... No
Probing for `IDT TS3000/TSE2002'... No
Probing for `IDT TSE2004'... No
Probing for `IDT TS3001'... No
Probing for `Maxim MAX6604'... No
Probing for `Microchip MCP9804'... No
Probing for `Microchip MCP9808'... No
Probing for `Microchip MCP98242'... No
Probing for `Microchip MCP98243'... No
Probing for `Microchip MCP98244'... No
Probing for `Microchip MCP9843'... No
Probing for `ON CAT6095/CAT34TS02'... No
Probing for `ON CAT34TS02C'... No
Probing for `ON CAT34TS04'... No
Probing for `Atmel AT30TS00'... No
Probing for `Giantec GT30TS00'... No
Client found at address 0x19
Probing for `National Semiconductor LM95231'... No
Probing for `National Semiconductor LM95241'... No
Client found at address 0x1a
Client found at address 0x1b
Client found at address 0x1c
Probing for `Texas Instruments TMP421'... No
Probing for `Texas Instruments TMP441'... No
Probing for `SMSC EMC1072'... No
Probing for `SMSC EMC1073'... No
Probing for `SMSC EMC1074'... No
Client found at address 0x1d
Probing for `TI / National Semiconductor ADC128D818'... No
Client found at address 0x1e
Client found at address 0x1f
Client found at address 0x28
Probing for `National Semiconductor LM78'... No
Probing for `National Semiconductor LM79'... No
Probing for `National Semiconductor LM80'... No
Probing for `National Semiconductor LM96080'... No
Probing for `Winbond W83781D'... No
Probing for `Winbond W83782D'... No
Probing for `Nuvoton NCT7802Y'... No
Probing for `Winbond W83627HF'... No
Probing for `Winbond W83627EHF'... No
Probing for `Winbond W83627DHG/W83667HG/W83677HG'... No
Probing for `Asus AS99127F (rev.1)'... No
Probing for `Asus AS99127F (rev.2)'... No
Probing for `Asus ASB100 Bach'... No
Probing for `Analog Devices ADM1029'... No
Probing for `ITE IT8712F'... No
Client found at address 0x29
Client found at address 0x2a
Client found at address 0x2b
Client found at address 0x2c
Probing for `Myson MTP008'... No
Probing for `National Semiconductor LM85'... No
Probing for `National Semiconductor LM96000 or PC8374L'... No
Probing for `Analog Devices ADM1027'... No
Probing for `Analog Devices ADT7460 or ADT7463'... No
Probing for `SMSC EMC6D100 or EMC6D101'... No
Probing for `SMSC EMC6D102'... No
Probing for `SMSC EMC6D103'... No
Probing for `SMSC EMC6D103S or EMC2300'... No
Probing for `SMSC EMC6W201'... No
Probing for `Winbond WPCD377I'... No
Probing for `Analog Devices ADT7470'... No
Probing for `Analog Devices ADT7473'... No
Probing for `Analog Devices ADT7476'... No
Probing for `Analog Devices ADT7490'... No
Probing for `Andigilog aSC7611'... No
Probing for `Andigilog aSC7621'... No
Probing for `National Semiconductor LM87'... No
Probing for `Analog Devices ADM1024'... No
Probing for `National Semiconductor LM93'... No
Probing for `National Semiconductor LM94 or LM96194'... No
Probing for `Winbond W83791D'... No
Probing for `Winbond W83792D'... No
Probing for `Winbond W83793R/G'... No
Probing for `Nuvoton W83795G/ADG'... No
Probing for `Genesys Logic GL518SM'... No
Probing for `Genesys Logic GL520SM'... No
Probing for `Analog Devices ADM9240'... No
Probing for `Dallas Semiconductor DS1780'... No
Probing for `National Semiconductor LM81'... No
Probing for `Analog Devices ADM1026'... No
Probing for `Analog Devices ADM1025'... No
Probing for `Philips NE1619'... No
Probing for `Maxim MAX6639'... No
Probing for `Analog Devices ADM1030'... No
Probing for `Analog Devices ADM1031'... No
Probing for `Analog Devices ADM1022'... No
Probing for `Texas Instruments THMC50'... No
Probing for `ALi M5879'... No
Probing for `SMSC LPC47M15x/192/292/997'... No
Probing for `SMSC DME1737'... No
Probing for `SMSC SCH5027D-NW'... No
Probing for `Winbond W83791SD'... No
Client found at address 0x2d
Probing for `Winbond W83783S'... No
Probing for `Nuvoton NCT7904D'... No
Probing for `Winbond W83L784R/AR/G'... No
Probing for `Winbond W83L785R/G'... No
Probing for `Genesys Logic GL525SM'... No
Probing for `VIA VT1211 (I2C)'... No
Probing for `Fintek F75373S/SG'... No
Probing for `Fintek F75375S/SP'... No
Probing for `Fintek F75387SG/RG'... No
Client found at address 0x2e
Probing for `Analog Devices ADT7467 or ADT7468'... No
Probing for `Analog Devices ADT7475'... No
Probing for `Winbond W83L786NR/NG/R/G'... No
Probing for `Winbond W83L785TS-S'... No
Probing for `Analog Devices ADM1028'... No
Probing for `Texas Instruments THMC51'... No
Probing for `SMSC EMC2103'... No
Client found at address 0x2f
Probing for `SMSC EMC2104'... No
Probing for `Fintek custom power control IC'... No
Client found at address 0x48
Probing for `National Semiconductor LM75'... No
Probing for `National Semiconductor LM75A'... No
Probing for `Dallas Semiconductor DS75'... No
Probing for `National Semiconductor LM77'... No
Probing for `Analog Devices ADT7410/ADT7420'... No
Probing for `Analog Devices ADT7411'... No
Probing for `Maxim MAX6642'... No
Probing for `Texas Instruments TMP435'... No
Probing for `National Semiconductor LM73'... No
Probing for `National Semiconductor LM92'... No
Probing for `National Semiconductor LM76'... No
Probing for `Maxim MAX6633/MAX6634/MAX6635'... No
Probing for `NXP/Philips SA56004'... No
Probing for `SMSC EMC1023'... No
Probing for `SMSC EMC1043'... No
Probing for `SMSC EMC1053'... No
Probing for `SMSC EMC1063'... No
Client found at address 0x49
Client found at address 0x4a
Client found at address 0x4b
Probing for `Analog Devices ADT7481'... No
Client found at address 0x4c
Probing for `Analog Devices ADT7466'... No
Probing for `Andigilog aSC7511'... No
Probing for `Global Mixed-mode Technology G781'... No
Probing for `National Semiconductor LM90'... No
Probing for `National Semiconductor LM89/LM99'... No
Probing for `National Semiconductor LM86'... No
Probing for `Analog Devices ADM1032'... No
Probing for `Maxim MAX6657/MAX6658/MAX6659'... No
Probing for `Maxim MAX6648/MAX6649/MAX6692'... No
Probing for `Winbond W83L771W/G'... No
Probing for `Winbond W83L771AWG/ASG'... No
Probing for `Texas Instruments TMP401'... No
Probing for `Texas Instruments TMP411A'... No
Probing for `Texas Instruments TMP422'... No
Probing for `Texas Instruments TMP423'... No
Probing for `Texas Instruments TMP431'... No
Probing for `Texas Instruments TMP432'... No
Probing for `Texas Instruments TMP442'... No
Probing for `Texas Instruments TMP451'... No
Probing for `National Semiconductor LM63'... No
Probing for `National Semiconductor LM96163'... No
Probing for `Fintek F75363SG'... No
Probing for `Analog Devices ADT7461'... No
Probing for `Analog Devices ADT7461A, ON Semiconductor NCT1008'... No
Probing for `Fintek F75383S/M'... No
Probing for `SMSC EMC1002'... No
Probing for `SMSC EMC1033'... No
Probing for `SMSC EMC1046'... No
Probing for `SMSC EMC1422'... No
Probing for `SMSC EMC1423'... No
Probing for `SMSC EMC1424'... No
Client found at address 0x4d
Probing for `Maxim MAX6659'... No
Probing for `Maxim MAX6646'... No
Probing for `Texas Instruments TMP411B'... No
Probing for `Fintek F75384S/M'... No
Client found at address 0x4e
Probing for `Maxim MAX6647'... No
Probing for `Texas Instruments TMP411C'... No
Probing for `Fintek F75121R/F75122R/RG (VID+GPIO)'... No
Probing for `Fintek F75111R/RG/N (GPIO)'... No
Probing for `ITE IT8201R/IT8203R/IT8206R/IT8266R'... No
Client found at address 0x4f
Probing for `SPD EEPROM'... No
Client found at address 0x51
Client found at address 0x53
Client found at address 0x58
Probing for `Analog Devices ADT7462'... No
Probing for `Andigilog aSC7512'... No
Client found at address 0x5c
Client found at address 0x73
Probing for `FSC Poseidon I'... No
Probing for `FSC Poseidon II'... No
Probing for `FSC Scylla'... No
Probing for `FSC Hermes'... No
Probing for `FSC Heimdal'... No
Probing for `FSC Heracles'... No
Probing for `FSC Hades'... No
Probing for `FSC Syleus'... No
Client found at address 0x77
Probing for `Asus Mozart-2'... No
Next adapter: NVIDIA i2c adapter 1 at 1:00.0 (i2c-4)
Do you want to scan it? (yes/NO/selectively): yes
Next adapter: NVIDIA i2c adapter 3 at 1:00.0 (i2c-5)
Next adapter: NVIDIA i2c adapter 5 at 1:00.0 (i2c-6)
Next adapter: NVIDIA i2c adapter 6 at 1:00.0 (i2c-7)
Sorry, no sensors were detected.
This is relatively common on laptops, where thermal management is
handled by ACPI rather than the OS.
And after detection:
$ sensors
hidpp_battery_0-hid-3-6
Adapter: HID adapter
in0: 4.13 V
BAT0-acpi-0
Adapter: ACPI interface
in0: 17.16 V
nvme-pci-0500
Adapter: PCI adapter
Composite: +49.9°C (low = -5.2°C, high = +79.8°C)
(crit = +84.8°C)
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +53.0°C
k10temp-pci-00c3
Tctl: +53.6°C
Tdie: +53.6°C
nvme-pci-0200
Composite: +38.9°C (low = -273.1°C, high = +83.8°C)
(crit = +84.8°C)
Sensor 1: +38.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +39.9°C (low = -273.1°C, high = +65261.8°C)
