Whenever I watch videos on YT, there are a lot of screen tearing.
So I searched the wiki for a solution, unfortunately none of those worked for me as it resulted in a black screen wherein the cursor is the only thing on the screen.
I have a Nvidia GT 730 and I already installed any proprietary drivers it have.
How will I fix the screen tearing aside from the solutions mentioned in the wiki?
    [manjaro@manjaro-ms7721 ~]$ inxi -Fxz
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  Desktop: Xfce 4.14.3 Distro: Manjaro Linux
  Type: Desktop Mobo: MSI model: A58M-E33 (MS-7721) v: 7.0 serial: <filter>
  UEFI: American Megatrends v: 32.6 date: 09/24/2014
  Info: Quad Core model: AMD A8-6600K APU with Radeon HD Graphics bits: 64
  type: MCP arch: Piledriver rev: 1 L2 cache: 2 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 31154
  Speed: 2067 MHz min/max: 1900/3900 MHz boost: enabled Core speeds (MHz):
  1: 2067 2: 2446 3: 1896 4: 1892
  Device-1: NVIDIA GF108 [GeForce GT 730] driver: nvidia v: 390.138
  bus ID: 01:00.0
  Device-2: Microdia Integrated Camera type: USB driver: uvcvideo
  bus ID: 1-5:2
  Display: x11 server: X.Org 1.20.10 driver: nvidia
  resolution: 1360x768~60Hz
  OpenGL: renderer: llvmpipe (LLVM 11.0.0 256 bits) v: 4.5 Mesa 20.3.1
  direct render: Yes
  Device-1: AMD FCH Azalia vendor: Micro-Star MSI driver: snd_hda_intel
  v: kernel bus ID: 00:14.2
  Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
  v: kernel bus ID: 01:00.1
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 02:00.0
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 763.85 GiB used: 120.53 GiB (15.8%)
  ID-1: /dev/sda vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
  ID-2: /dev/sdb vendor: Western Digital model: WD3200AAJS-00L7A0
  ID-1: / size: 62.23 GiB used: 11.37 GiB (18.3%) fs: ext4 dev: /dev/sdb6
  ID-2: /boot/efi size: 96 MiB used: 31.8 MiB (33.1%) fs: vfat
  dev: /dev/sdb2
  System Temperatures: cpu: 25.4 C mobo: N/A gpu: nvidia temp: 52 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 52%
  Processes: 188 Uptime: 2h 26m Memory: 7.78 GiB used: 3.56 GiB (45.7%)
  Init: systemd Compilers: gcc: 10.2.0 Packages: 1211 Shell: Bash v: 5.1.0
  inxi: 3.2.01
