I don’t know how the GRUB Menu got changed but GRUB is only supposed to be install on the Manjaro Drive, and not boot to the Windows 10 one.
The way I had it was if I boot boot Computer w/o press F11, Windows 10 boots. If F11 is press while booting then I can boot into Manjaro.
Now this has change. GRUB now shows up when my Booting my Rig. How do I change this back the way it was?
Ben
2
GRUB installs where you tell it to install I believe. I think you’ll need to use a Windows install USB/disk to fix the ‘Microsoft Reserved Partition’…
Take a look at this:
https://medium.com/@hetmansoftware/how-to-restore-the-structure-of-deleted-efi-partitions-in-windows-653a68b5c09f
Why does that ‘circle of dots’ give me the creeps?
I’ll try this and report back.
