How to fix (Failed to synchronize databases)?
whenever i try to install any package then i get this type of message (Failed to synchronize databases
how to fix this error ??
Is the search function of the forum also failing you?
https://forum.manjaro.org/search?q=Failed%20to%20synchronize%20databases
xdman.db failed to download
error: failed retrieving file ‘xdman.db’ from sourceforge_net : The requested URL returned error: 404
error: failed to synchronize all databases (failed to retrieve some files)
still the same error…
Did you try in terminal:
pamac build xdman
Assuming that you have base-devel package installed.
Third-party repos are not supported. Remove the repo from your pacman.conf and update.
Thank You it’s working
