Yes, I found this forum page before, but there isn’t a good solution there, just the cause of the problem and a guy who solved by using
1-. $conda deactivate
2-. $yay -Syu
3-. $source [PATH TO CONDA]/bin/activate (in my case, source $HOME/anaconda3/bin/activate)
4-. $conda init
Which didn’t worked for me.
I have look for many forums, but so far none have gave a good solution, only explained the cause of the problem.
I’m not using conda base right now
This might is a way to fix it ?
But i couldn’t understand how would i change the path
Quick fix: export PATH=/usr/bin:$PATH
Longer version:
Check with: which bsdtar
If your bsdtar is set to something like: /opt/anaconda/bin/bsdtar
Prepending /usr/bin/ to the PATH variable forces bsdtar to be found from /usr/bin/.
