Hi,
a package (X) was installed as a dependency for another package (Y).
Which command do I use to find which package (Y) breaks if I delete the dependency (X)?
So basically, the command for checking which packages (Y) depend on package (X)?
Hi,
You can use pactree with the -r option. The program is part of Looks like the package pacman-contrib .pacman-contrib is not part of Manjaro, in Manjaro pactree is part of the pacman package.
Thank you.
Badass ![]()
