Hi there,
I need some support on the following:
- I have a 64gb sdxc with Manjaro installed on it. I use it on my laptop (I’ve other SO installed on laptop hard disk). Details at the bottom.
- I installed Manjaro (a while ago) I think moving from another SD using “dd”
- All was working fine until this evening where I lunched an update, I got a file system full
- I took the sdxc on my desktop and run
sudo lsblk -o FSSIZE,FSUSED /dev/sdc2getting SIZE=14.2GB USED=12.6GB.
So I understand I’ve a filesystem of 14GB on a filesystem/partition of about 60GB.
How can I extend the filesystem, without loosing its content and its “bootability”?
Thx!
Disk /dev/sdc: 59.48 GiB, 63864569856 bytes, 124735488 sectors
Disk model: SD Card Reader
Disklabel type: gpt
Disk identifier: D302FEDE-5DAD-4158-B920-FD9D7C58177B
Device Start End Sectors Size Type
/dev/sdc1 4096 618495 614400 300M EFI System
/dev/sdc2 618496 124728659 124110164 59.2G Linux filesystem
