How to enforce a mesa driver override in a python script?
I need to start MATLAB with the parameters “env MESA_LOADER_DRIVER_OVERRIDE=i965”. I could edit my .desktop file and also add an alias in .bashrc. Now I need to set this environment override in a python script. I have tried
os.environ['env MESA_LOADER_DRIVER_OVERRIDE=i965']
and
os.environ['MESA_LOADER_DRIVER_OVERRIDE=i965']
Unfortunately both throw an error. And well sure - both of them are bash commands. I probably need to set something like a .pythonrc up.
If you want env vars from the system you need
import os
To set them ex:
os.environ[MESA_LOADER_DRIVER_OVERRIDE]=i965
You can print them with ex:
print(os.environ['MESA_LOADER_DRIVER_OVERRIDE'])
Tried that and I am getting this error
 File "~/.config/nvim/plugged/vim-matlab/ftplugin/matlab/../../scripts/vim-matlab-server.py", line 28, in <module>
 os.environ[MESA_LOADER_DRIVER_OVERRIDE]=i965        │
 NameError: name 'i965' is not defined
 [Process exited 1]
Since it already imports os, do I maybe have to set this environment variable in my .xintrc? The problem is that I only need this driver for MATLAB. I don’t want to set it as a global driver. An alias would work better, but that probably doesn’t get piped into python, does it?
Solution was:
env = os.environ.copy()
env['MESA_LOADER_DRIVER_OVERRIDE'] = 'i965'
self.proc = Popen(["matlab", "-nosplash", "-nodesktop"], stdin=PIPE,
                          close_fds=True, preexec_fn=os.setsid, env=env)
