i am trying to fix a problem with nvidia and going through the steps to get a bug report. one of the steps is to enable “-logverbose 6” on the xorg server launcher. after looking thorugh the display manager(sddm) i found that xorg is started with the “startplasma-x11” binary. i am going to create a new session in the sddm launcher to run the command at startup so i am wondering if this is the correct binary to use the logverbose setting in the case of kde?
seems i was looking in the wrong place as you are suppose to add x11 server arguments into a sddm config.
for anyone else who looks this up trying to do the same thing.
create a file called “verbose.conf”(can be called anything but this is easier to remember what it does) in “/etc/sddm.conf.d/” with this in it
[X11]
ServerArguments=-nolisten tcp -logverbose 6
for lightdm, edit /etc/lightdm/lightdm.conf and under [Seat:*] uncomment the line #xserver-command=X and add -logverbose 6
New full line:
xserver-command=X -logverbose 6
