KDE Plasma 5.25 has said to have these gestures on touchpad:
A four-finger pinch opens the Overview.
A three-finger swipe in any direction will switch between Virtual Desktops.
A downwards four-finger swipe opens Present Windows.
A four-finger upwards swipe activates the Desktop Grid.
but I installed libinput
and libinput-gestures
, nothing happened. I cannot use these gestures.
inxi -Fazy
Kernel: 5.18.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=84aec800-1dbc-4e2e-91f7-c1659f2154a6 rw quiet nowatchdog
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20WKA000CD v: ThinkPad X13 Gen 2i
Mobo: LENOVO model: 20WKA000CD v: SDK0L77769 WIN
serial: <superuser required> UEFI: LENOVO v: N35ET47W (1.47 )
date: 05/13/2022
ID-1: BAT0 charge: 28.6 Wh (52.3%) condition: 54.7/54.7 Wh (100.0%)
volts: 15.1 min: 15.4 model: Sunwoda 5B10W51820 type: Li-poly
serial: <filter> status: discharging cycles: 128
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2091 high: 3281 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 2425 2: 3281 3: 2137
4: 2773 5: 1389 6: 2560 7: 1052 8: 1115 bogomips: 44864
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 3-4:5 chip-ID: 13d3:5271 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 192 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: eDP-1 model-id: CSO 0x1305 built: 2020 res: 2560x1600 hz: 60
dpi: 227 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 2560x1600
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.18.10-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.54 running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fc class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
IF-ID-1: wwp0s20f0u2i1 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-10:6 chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 982.52 GiB used: 134.61 GiB (13.7%)
model: MZVL21T0HCLR-00BL7 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: CL2QGXA7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 125.63 GiB size: 123.1 GiB (97.98%)
used: 57.78 GiB (46.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
used: 29.1 MiB (30.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 65535 fan-1: 2568 fan-2:
Processes: 235 Uptime: 18m wakeups: 913 Memory: 15.35 GiB
used: 3.74 GiB (24.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1287
lib: 386 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.19
