I think the intended suggestion might have been to try obtaining the ubuntu sound from an Ubuntu install; perhaps on VM; if you really wanted that startup sound.
However, if I’m wrong, I have confidence that @Mirdarthos will say so. ![]()
Ahhh okay I see! Sorry my brain was too slow for that match
Yeah okay, I’ll just get me something neat to play at startup, all good! And thanks for your help ![]()
@soundofthunder is correct. I was under the impression that you had an Ubuntu available somehow. I was obviously wrong.
But, at least now you can play your choice of startup sound. (That was what I was presuming you were trying to do anyway.)
Open Terminal and create the .config/autostart folder in case it does not exit.
mkdir -p ~/.config/autostart
Use a text editor to generate and edit a ‘login-sound.desktop ‘ file
gedit ~/.config/autostart/login-sound.desktop
Copy and paste these line to ‘login-sound.desktop ‘ file
[Desktop Entry]
Encoding=UTF-8
Exec=paplay /usr/share/sounds/freedesktop/stereo/service-login.oga
Name=Login Sound
Comment=Play a sound at login
Terminal=false
OnlyShowIn=GNOME
Type=Application
StartupNotify=false
X-GNOME-Autostart-enabled=true
Save it. Then logout and login to check the sound
Hi! Did you try creating a script or a .desktop file and add it to the startup section in Gnome Tweaks? Worked for me to start conky with other programs the way I wanted.
Edit: Pretty much what arun.sebastian said ![]()
