Hi, so here I am again, I tried to read and do stuff, but I still failed. Now on to my problem:
I just installed PCSXR using AUR, and chose the stable version
$ yay -S pcsxr
So, for the past day, I am trying to enable some shaders plugin so at least I could enjoy my old games on my Manjaro. but I couldn’t see any option on how to enable it.
According to the PCSXR Wiki, in order to enable plugins I needed to Install the 32 bit version from the multilib repositories
More Info
yay -Ss pcsxr
aur/lib32-pcsxr 1.9.93-5 (+0 0.00) A Sony PlayStation (PSX) emulator based on the PCSX-df project (lib32) aur/pcsxr-gtk2 1.9.92-2 (+6 0.00) A Sony PlayStation (PSX) emulator based on the PCSX-df project (Gtk2 version) aur/pcsxr-pgxp-git 1.9.94.r1731.62467b86-2 (+7 0.04) A Sony PlayStation (PSX) emulator based on the PCSX-df Project with Parallel/Precision Geometry Transform Pipeline aur/pcsxr 1.9.95-2 (+15 0.05) (Installed) A Sony PlayStation (PSX) emulator based on the PCSX-df project aur/pcsxr-git 1.9.94.r1697.6484236c-1 (+45 0.02) A Sony PlayStation emulator based on the PCSX-df Project
cat /etc/pacman.conf ⌦ This is for checking multilib repository if enabled
# # /etc/pacman.conf # # See the pacman.conf(5) manpage for option and repository directives # # GENERAL OPTIONS # [options] # The following paths are commented out with their default values listed. # If you wish to use different paths, uncomment and update the paths. #RootDir = / #DBPath = /var/lib/pacman/ CacheDir = /var/cache/pacman/pkg/ #LogFile = /var/log/pacman.log #GPGDir = /etc/pacman.d/gnupg/ #HookDir = /etc/pacman.d/hooks/ HoldPkg = pacman glibc manjaro-system # If upgrades are available for these packages they will be asked for first SyncFirst = manjaro-system archlinux-keyring manjaro-keyring #XferCommand = /usr/bin/curl -C - -f %u > %o #XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u #CleanMethod = KeepInstalled #UseDelta = 0.7 Architecture = auto #IgnorePkg = #IgnorePkg = #IgnoreGroup = #NoUpgrade = #NoExtract = # Misc options #UseSyslog #Color #TotalDownload # We cannot check disk space from within a chroot environment CheckSpace #VerbosePkgLists # By default, pacman accepts packages signed by keys that its local keyring # trusts (see pacman-key and its man page), as well as unsigned packages. SigLevel = Required DatabaseOptional LocalFileSigLevel = Optional #RemoteFileSigLevel = Required # NOTE: You must run `pacman-key --init` before first using pacman; the local # keyring can then be populated with the keys of all official Manjaro Linux # packagers with `pacman-key --populate archlinux manjaro`. # # REPOSITORIES # - can be defined here or included from another file # - pacman will search repositories in the order defined here # - local/custom mirrors can be added here or in separate files # - repositories listed first will take precedence when packages # have identical names, regardless of version number # - URLs will have $repo replaced by the name of the current repo # - URLs will have $arch replaced by the name of the architecture # # Repository entries are of the format: # [repo-name] # Server = ServerName # Include = IncludePath # # The header [repo-name] is crucial - it must be present and # uncommented to enable the repo. # # The testing repositories are disabled by default. To enable, uncomment the # repo name header and Include lines. You can add preferred servers immediately # after the header, and they will be used before the default mirrors. [core] SigLevel = PackageRequired Include = /etc/pacman.d/mirrorlist [extra] SigLevel = PackageRequired Include = /etc/pacman.d/mirrorlist [community] SigLevel = PackageRequired Include = /etc/pacman.d/mirrorlist # If you want to run 32 bit applications on your x86_64 system, # enable the multilib repositories as required here. [multilib] SigLevel = PackageRequired Include = /etc/pacman.d/mirrorlist # An example of a custom package repository. See the pacman manpage for # tips on creating your own repositories. #[custom] #SigLevel = Optional TrustAll #Server = file:///home/custompkgs
is the lib32-pcsxr the 32 bit version? If yes, is it ok If I just installed it without uninstalling the one I currently have, will it overwrite the installation?
