I click the mouse anywhere on the terminal or nano, the pointer does not go there
How to enable xfce terminal mouse click move the cursor?
It doesn’t work like that. A terminal is a character device.
What you could try is install gpm
if it’s not installed already, and then make sure that it’s enabled.
sudo pacman -S gpm
systemctl enable --now gpm.service
You may already know that but for editing files you may use GUI editing tools like Kate for example.
