My laptop has a touchscreen that used to work under Linux, but it stopped working a while ago and I’m not sure why. I’m using X, not Wayland. Here’s what I already tried doing to re-enable the touchscreen:
~ ❱ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech Gaming Mouse G600 id=10 [slave pointer (2)]
⎜ ↳ MELF0411:00 1FD2:4010 Touchscreen id=13 [slave pointer (2)]
⎜ ↳ ETPS/2 Elantech Touchpad id=15 [slave pointer (2)]
So you can see that it recognizes that I have a touchscreen.
~ ❱ xinput enable 13
~ ❱ xinput list-props 13
Device 'MELF0411:00 1FD2:4010 Touchscreen':
Device Enabled (185): 1
Coordinate Transformation Matrix (187): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Calibration Matrix (346): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Calibration Matrix Default (347): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Send Events Modes Available (307): 1, 0
libinput Send Events Mode Enabled (308): 0, 0
libinput Send Events Mode Enabled Default (309): 0, 0
Device Node (310): "/dev/input/event7"
Device Product ID (311): 8146, 16400
Here you can see that it says that the device is enabled, but it still doesn’t work.
I installed all the drivers listed on the archwiki page (https://wiki.archlinux.org/title/Touchscreen
), and it still doesn’t work.
~ ❱ less /proc/bus/input/devices
N: Name="MELF0411:00 1FD2:4010 Touchscreen"
P: Phys=i2c-MELF0411:00
S: Sysfs=/devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-1/i2c-MELF0411:00/0018:1FD2:4010.0001/input/input13
U: Uniq=
H: Handlers=event7 mouse0
B: PROP=0
B: EV=1b
B: KEY=400 0 0 0 0 0
B: ABS=10000000003
B: MSC=10
This command also shows that the touchscreen gets recognized as existing.
~ ❱ sudo cat /dev/input/event7
This doesn’t output anything, even when I run my finger over the screen.
~ ❱ cat /usr/share/X11/xorg.conf.d/10-evdev.conf
Section "InputClass"
Identifier "evdev touchscreen catchall"
MatchIsTouchscreen "on"
MatchDevicePath "/dev/input/event*"
Driver "evdev"
EndSection
~ ❱ cat /usr/share/X11/xorg.conf.d/40-libinput.conf
Identifier "libinput touchscreen catchall"
Driver "libinput"
EndSection
I didn’t disable it in any of these conf files.
~ ❱ udevadm info --export-db
P: /devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-1/i2c-MELF0411:00/0018:1FD2:4010.0001/input/input13/event7
N: input/event7
L: 0
S: input/by-path/pci-0000:00:15.3-platform-i2c_designware.1-event
E: DEVPATH=/devices/pci0000:00/0000:00:15.3/i2c_designware.1/i2c-1/i2c-MELF
E: SUBSYSTEM=input
E: DEVNAME=/dev/input/event7
E: MAJOR=13
E: MINOR=71
E: USEC_INITIALIZED=3061740
E: ID_INPUT=1
E: ID_INPUT_TOUCHSCREEN=1
E: ID_INPUT_WIDTH_MM=341
E: ID_INPUT_HEIGHT_MM=195
E: ID_PATH=pci-0000:00:15.3-platform-i2c_designware.1
E: ID_PATH_TAG=pci-0000_00_15_3-platform-i2c_designware_1
E: LIBINPUT_DEVICE_GROUP=18/1fd2/4010:i2c-MELF0411:00
E: DEVLINKS=/dev/input/by-path/pci-0000:00:15.3-platform-i2c_designware.1-event
It literally even says here ID_INPUT_TOUCHSCREEN=1
So I’m confused why despite every program saying that the device is a touchscreen, and that it is enabled and turned on, it’s still not working.
The touchscreen isn’t broken because it still works just fine when I dual boot Windows.
