How to enable features in manjaro minimal?
HI Team,
Previously i have installed full featured Manjaro ISO, now i have changed it to minimal.
After changing to minimal i cannot able to find SNAP in Pacmac, When i am trying to install Openoffice no packages found with that name.
I Just want all packages which full iso offer, how i can add them in this minimal build?
Please guide me how i can install openoffice and how i can enable Snapd in pacmac.
Welcome to the forum! :wave:
Then why did you use the minimal ISO? :thinking:
It’s an optional dependency of pamac-gtk called libpamac-snap-plugin.
You can install any software you like via Add/Remove Software.
Ummm, isn’t the whole point of a minimal install the lack of unnecessary packages?
Why do you need snap on a minimal install? Why wouldn’t you simply install a standard OpenOffice package using pamac rather than a snapd package?
HI Thank you for reply,
Just now i installed Snapd in Pacmac.
