hi, I want to use the jgmenu to launch gnome-terminal instead of termite (that came as default when I installed Manjaro Openbox).
I did edit the jgmenurc in ~/.config/jgmenu/ this way, from:
terminal_exec = termite
to
terminal_exec = gnome-terminal
… but it doesn’t work
What should I do?
I did have a look at the jgmenu docs, but was soon lost in all the details…
Many thanks!
jgmenu runs in the background so for a change to the config to reflect you need to kill the process
pkill jgmenu
you may need to edit the prepend.csv as well
thanks, it was the prepend.csv bit (I forgot to write but I had killed the process)
