It all works fine except for jupyiter, which is broken because of the visual studio code version, how do I install a previous version?
Extension activation failed, run the 'Developer: Toggle Developer Tools' command for more information.
Completely a visual studio code issue, but I don’t know how to revert to previous versions
Wollie
16 October 2021 20:04
2
Have you seen this wiki entry:
https://wiki.manjaro.org/index.php?title=Downgrading_packages
Be aware, downgrading is risky and theoretically can break your system. Use it with care.
I am going to try and use the downgrade command, do you have a version that you can recommend that you know is safe and compatible?
I think its better to use flatpak to install older version
https://flathub.org/apps/details/com.visualstudio.code
Lolix
17 October 2021 18:59
5
How do you have installed VS Code? From the AUR?
Which the version you need?
Yeah, just from Add/Remove Software
Not sure, but not this one
I tried this, but flatpak’s code is a bit weird and the dark theme only shows the code dark.When I open folders and files its all white, and the top bar is while. It looks less aesthetic. When I try to reinstall code, I uninstalled it, I get operation cancelled due to ignorepkg (I used downgrade on code) - How do I remove the ignorepkg
Lolix
18 October 2021 11:32
8
So let’s build v1.61.0 which is the previous version, open a terminal and write:
git clone https://aur.archlinux.org/visual-studio-code-bin.git
cd visual-studio-code-bin
git checkout 506c9e98697709747feba7560c1cd3dd690827c0
makepkg -si
You can see git history using the git log command
system
Closed
21 October 2021 01:32
9
