You can still use old packages residing in your package cache (/var/cache/pacman/pkg).
Mind you: if you do downgrade, remember to downgrade all foursystemd packages together (systemd, systemd-libs, lib32-systemd, systemd-sysvcompat).
Switching to another branch (hint: testing) also enables DOWNGRADE_FROM_ALA functionality…
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
I don’t have any package in my cache. So this is NO solution.
The seconds proposal switching to “testing” branch is also no solution, because then I will get a lot of updates I don’t want on my productive system.
So is there really no chance do downgrad a package in Manjaro if you donÄt have it in your personal pkg cache? Really? This looks like a problem by design???!!!
I think the intention was that with setting the environment variable DOWNGRADE_FROM_ALA=1, downgrade should allow ALA even on stable (which does not work).
Anyways, you could grab the original downgrade as a temporary workaround:
Please keep in mind that Manjaro build some packages by its own.
The downgrade from a server works IMHO only for package that are directly imported from Arch. If a package is build by Manjaro developer, it needs to be in your cache.
If your really need a special version of a core system package, downgrade is never a good solution or workaround. In such cases, get the sources from gitlab.manjaro.org and build it against the current set of packages yourself.
Just to explain why your commands did not work: you’re setting the environment variable in your local environment of your current user but execute the command with sudo - which wasn’t instructed to keep the current environment - therefor the variable is not visible for the command.
