Hi, I need to install an old version of the avr-gcc package because of a problem described here: Sketch too big with gcc 9.1.0 · Issue #663 · gnea/grbl · GitHub
The version I need is avr-gcc-8.3.0, it’s from 2019 I think. Is there a way to install this specific version of a package?
Thanks!
avr-gcc
is inherited directly from the Arch repos. The latest version there is 11.2.0-1
. You can grab the PKGBUILD
for the 8.3.0
version from the package commit history available on github.
To install/downgrade to that version make a new directory and copy the PKBUILD
and run makepkg -si
. If avr-gcc
is already installed on your system, pacman should ask you if you want to downgrade or not.
mkdir ~/avr-gcc
cd ~/avr-gcc
wget https://raw.githubusercontent.com/archlinux/svntogit-community/c2d80621d1a9d37c13bd85604d902d3ac11915ea/trunk/PKGBUILD
sudo pacman -S base-devel git --needed
makepkg -si
Thank you very much for your reply!
Unfortunately, I was unable to build the package successfully, I got “ERROR: A failure occurred in build().
”. Maybe I’ll investigate this further in the future, but for now, I managed to use a VM with Ubuntu to build the firmware I needed, as they still use that old avr-gcc version.
Thanks again.
