I’ve updated my system yesterday and now I’ve got Firefox 90 which has completely broken it’s printing feature.
How can I downgrade to a pre v90 version of firefox?
You can install an older version from your cache, but it might not launch because of dependency versions have also changed.
sudo pacman -U /var/cache/pacman/pkg/firefox-$pkgver*
thanks for the amazingly fast reply!
tried what you suggested, though I have problems with depending packages. Can I downgrade them at the same time?
$ sudo pacman -U /var/cache/pacman/pkg/firefox-89.0.2-0.1-x86_64.pkg.tar.zst
loading packages...
warning: downgrading package firefox (90.0-1 => 89.0.2-0.1)
resolving dependencies...
:: installing firefox (89.0.2-0.1) breaks dependency 'firefox>=90.0' required by firefox-i18n-de
:: installing firefox (89.0.2-0.1) breaks dependency 'firefox>=90.0' required by firefox-i18n-en-us
ah, yes, I was able to downgrade using this:
$ cd /var/cache/pacman/pkg
$ sudo pacman -U firefox-89.0.2-0.1-x86_64.pkg.tar.zst firefox-i18n-de-89.0.2-1-any.pkg.tar.zst firefox-i18n-en-us-89.0.2-1-any.pkg.tar.zst
But now it doesn’t want to load my profile anymore and I could only start with a different profile
ahh, there’s an -allow-downgrade parameter
https://support.mozilla.org/en-US/questions/1287075
Before I forget again:
Downgrading packages creates what is know as a “partial update” state, which is not supported by Arch or Manjaro.
All the packages in the repository, are built againt what is currently in the repository, which changes all the time on a rolling release. So holding back an update, like you just did by installing an older version, will likely break at some point because of dependency versions changing.
In the example of Firefox, it depends on nss
and it can break if nss
updates and firefox is not rebuilt againt that version of nss. And downgrading might break other packages depending on that version of nss. And now you are in a loop of partial updated dependencies.
So the general rule is, always update everything. If you don’t like how something changed, it might be time to look for an alternative application or even Operating System.
PS: Firefox 90 is able to print just fine. Just printed one of the webpaged I have open as a test.
well, for me it doesn’t print fine, at least not all pages it did print fine before the upgrade.
And I’m not the only one with this issue:
Luckily for me, for now the downgraded firefox still works on my Manjaro system.
I understand that once it stops beeing so easy to use the previous version by downgrading using the locally cached package (because of more complex dependencies / incompatibilities), I will have to look for alternative solutions.
But I kind of hope they fix the printing feature before that happens.
