Hy, I recently installed Manjaro linux, It’s great OS much smoother than win11, but games were crashing , found out there was no swap memory created by default,
so I created one manually, and crashing problem solved at some extend, now I wanna try Zram, but for that to work efficiently, Zswap need’s to be disabled.
I changed changed grub conf: /etc/default/grub
and added
zswap.disable=1
to
“GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3 zswap.disable=1
save and sudo update-grub
reboot
after booting again: zgrep CONFIG_ZSWAP_DEFAULT_ON /proc/config.gz
still returns: CONFIG_ZSWAP_DEFAULT_ON=y
cat /sys/module/zswap/parameters/enabled
returns: Y
KDE Plasma Version: 5.27.11
KDE Frameworks Version: 5.115.0
Qt Version: 5.15.12
Kernel Version: 6.6.26-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 12 × AMD Ryzen 5 5500U with Radeon Graphics
Memory: 7.1 GiB of RAM
