Hi , I want to know , When watching online film on web , How to disable a screensaver . I know where to find screensaver settings , but there is only options for start screensaver after unactivity . Thanks
Easy way
is in our repoâŚ
Thank you , I am beginner .
You can outright disable the automatic screensaver and session lock, though that may be overkillâŚ
Checkout the xset command.
Xfce power management has a Presentation Mode to disable screensaver or suspend settings
Left click Power Manager plugin in system tray to turn it on
or use this command to toggle Presentation Mode on/off
xfconf-query -c xfce4-power-manager -p /xfce4-power-manager/presentation-mode -T
Right click and selecting Power Manager Preferences has an option to show an additional indicator when Presentation Mode is on
If you, like me, donât care about the screen being changed/dimmed/switched off after some time:
I have disabled the screensaver
as well as the display power management
just for that same reason.
I donât need a screensaver anyway
and the display power management is what gets in the way here.
You reach it directly via:
LANG=C xfce4-power-manager-settings --> the "Display" tab
switch it off for both âOn Batteryâ and âPlugged inâ
But maybe the caffeine solution is better for you - but you may have to remember to activate it each time
(it says it will activate itself when something is put into fullscreen, so it should be a good tool for this purpose, watching movies âŚ)
