Broadcast message from username@Desktop (Sun 1919-08-10 11:45:14 CST):
The system is going to reboot NOW!
[756.345947] watchdog: watchdog0: watchdog did not stop!
[756.472889] watchdog: watchdog0: watchdog did not stop!
Every time I reboot and found a message like this.
Is there any way to get rid of these messages?
Manjaro version: Testing Update 20220709
Kernel: 5.18.10-1-MANJARO x86_64
It needs to go away again.
First: which Watchdog do yo have?
==> lsmod | grep -e dog -e wdt -e tco
Then: blacklist it.
Example:
journalctl -p err -b
sp5100-tco sp5100-tco: Watchdog hardware is disabled
That requires /etc/modprobe.d/blacklist_tco.conf with content: blacklist sp5100_tco
sudo nano /etc/modprobe.d/blacklist_tco.conf
More: Reboot doesn't work? - #31 by Stagger_Lee - General system - EndeavourOS
or Watchdog did not stop
iTCO_wdt 16384 0
intel_pmc_bxt 16384 1 iTCO_wdt
iTCO_vendor_support 16384 1 iTCO_wdt
Jul 10 23:18:52 ThinkPad kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Jul 10 23:18:52 ThinkPad kernel: pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
Jul 10 23:18:52 ThinkPad systemd-udevd[285]: could not read from '/sys/module/pcc_cpufreq/initstate': No such>
Jul 10 23:18:53 ThinkPad kernel: spi-nor spi0.0: BFPT parsing failed. Please consider using SPI_NOR_SKIP_SFDP>
Jul 10 23:18:55 ThinkPad kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jul 10 23:18:55 ThinkPad systemd[517]: Failed to start Update XDG user dir configuration.
Jul 10 23:19:02 ThinkPad kernel: ntfs3: Unknown parameter 'windows_names'
So do in terminal:
contents: EDIT:
blacklist iTCO_wdt
blacklist iTCO_vendor_support
followed by saving the new created file with contents above and finally reboot. Thats all.
I have this file and I have nowatchdog
in kernel parameters
you have to blacklist these 2 + adding the nowatchdog parameter:
blacklist iTCO_wdt
then reboot and test with these commands:
cat /proc/sys/kernel/watchdog
cat /proc/sys/kernel/nmi_watchdog
both should give: ‘0’
Brahma is correct, my failure…
? nowatchdog is not needed if blacklisted? Either-or
My
solved by using
only, in /etc/modprobe.d/blacklist_tco.conf
No warnings after.
Yes, nowatchdog is not needed. But the broadcast message still exists. I regard it as a bug.
Although I did not find it in systemd’s github issues.
