Thanks @soundofthunder. Here is the output of inxi --filter --verbosity=8 on my system:
Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=88025b4c-36f6-4f08-9860-5c5493af9d61 rw quiet splash
resume=UUID=a6888ecb-bf5c-4e3b-8997-c58d906dd54c udev.log_priority=3
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: 3.60 date: 04/22/2020
System RAM: total: 16 GiB available: 15.56 GiB used: 4.1 GiB (26.3%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
part-no: 3000 C16 Series serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 2
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
desc: 8x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2200 min/max: 2200/4426 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 115250
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 14 [Radeon RX 5500/5500M /
Pro 5500M] vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1
code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 28:00.0 chip-ID: 1002:7340 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5
chip-ID: 046d:082d class-ID: 0102 serial: <filter>
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) Ultra HD serial: <filter>
built: 2018 res: mode: 3840x2160 hz: 60 scale: 140% (1.4) to: 2743x1543
dpi: 163 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green: x: 0.306
y: 0.639 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 93 4: parse_edid:
unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi
navi14 LLVM 19.1.7 DRM 3.61 6.12.19-1-MANJARO) device-ID: 1002:7340
memory: 7.81 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.304 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: N/A device-ID: 1002:7340
surfaces: xcb,xlib,wayland
Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
bus-ID: 28:00.1 chip-ID: 1002:ab38 class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 21:00.0 chip-ID: 8086:2723 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 2.07 TiB used: 35.67 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 4C scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: HFM256GDGTNG-87A0A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: GPT
ID-1: / raw-size: 936.45 GiB size: 920.68 GiB (98.32%)
used: 35.67 GiB (3.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 88025b4c-36f6-4f08-9860-5c5493af9d61
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1E0E-0503
ID-1: swap-1 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: a6888ecb-bf5c-4e3b-8997-c58d906dd54c
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: Backup
uuid: 7db4ecb3-241c-434b-bc99-2b14a11c792c
ID-2: /dev/sdb1 maj-min: 8:17 size: 238.47 GiB fs: ext4 label: Personal
uuid: 8b1af876-16b0-450c-8b1a-6f7a5c8f83b7
Device-1: 1-3:2 info: Realtek RTL9210 M.2 NVME Adapter type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:9210 class-ID: 0806
serial: <filter>
Device-2: 1-4:3 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 1050:0407 class-ID: 0b00 serial: <filter>
Device-3: 1-6:4 info: Cooler Master AMD SR4 lamplight Control
type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 2516:0051 class-ID: 0300
Device-4: 1-8:5 info: Logitech HD Pro Webcam C920 type: video,audio
Device-5: 1-10:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-1: 3-1:2 info: Razer USA Viper (wired) type: mouse,keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:0078 class-ID: 0301
Device-2: 3-2:3 info: Razer USA RZ03-0338 Gaming Keyboard [Ornata V2]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
chip-ID: 1532:025d class-ID: 0300
System Temperatures: cpu: 51.5 C mobo: N/A gpu: amdgpu temp: 57.0 C
mem: 0.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: pm: pacman pkgs: 1292 libs: 365 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
7: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
8: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 405
1: cpu: 7.2% command: konsole pid: 8728 mem: 233.1 MiB (1.4%)
2: cpu: 5.8% command: firefox pid: 1719 mem: 827.8 MiB (5.1%)
3: cpu: 3.2% command: zsh pid: 8749 mem: 9.66 MiB (0.0%)
4: cpu: 2.2% command: kwin_wayland pid: 968 mem: 316.7 MiB (1.9%)
5: cpu: 1.2% command: firefox pid: 2279 mem: 576.5 MiB (3.6%)
Memory top: 5 of 405
1: mem: 827.8 MiB (5.1%) command: firefox pid: 1719 cpu: 5.8%
2: mem: 611.7 MiB (3.8%) command: firefox pid: 2536 cpu: 1.1%
3: mem: 576.5 MiB (3.6%) command: firefox pid: 2279 cpu: 1.2%
4: mem: 507.1 MiB (3.1%) command: plasmashell pid: 1242 cpu: 0.2%
5: mem: 321.7 MiB (2.0%) command: firefox pid: 3889 cpu: 0.5%
Processes: 405 Power: uptime: 1h 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
