How to disable auto login?
How to cancel automatic login when the system is powered on?
please rephrase your topic to use proper language.
Thank you.
use the search function
use the system settings panel
Go to System Settings → Workspace → Startup and Shutdown → Login Screen (SDDM), and click the Behavior button (you’ll find it near the bottom of the window). There you uncheck the Automatically log in as user…
