Hi I’m new to Linux and Manjaro. Recently, I move my home folder to a new partition and mounted my new partition to /home. But, I forgot to delete the old home folder thus the data is still in the root partition. Is there any way I can delete it? Do let me know if any info is needed
Hi and welcome to the forum
To do that you need to:
- Boot from a Live image (USB/DVD)
- Mount that root partition at
/mnt
- You will now be able to remove the contents of
/mnt/home
Keep in mind that you should not remove/mnt/home
itself, because it is needed as mount point in your normal setup… - Execute sync and reboot into your normal OS.
Thanks that solved my problem!
