I’d like to delete my encrypted swap partition and use the empty space for my main partition, but I don’t know how to do it properly. I use full disk encryption on this SSD. Do I need to do this from a live USB ? If you have some step by step instructions, that would help me a lot !
I think that I forgot to mention that I use full disk encryption on my SSD. So it’s really just as simple as using gparted on a live-usb ? No need afterwards to edit anything in fstab / crypttab or in /etc/default/grub ? gparted takes care of all of this ?
@LowTokyo5, as @Keruskerfuerst already mentioned you need to first disable your swap from your current system:
Check inside /etc/fstab and /etc/crypttab for any signs of swap configurations, and disable them when found.
Reboot your system to make sure it does not use the Swap partition.
Double check with swapon -s
If after these steps you are certain that the swap partition is not used anymore, you can use your favorite partitioning tool to re-assign the swap partition for other usage.
