I’d like to know if there is away to delay the start of a systemd service during boot. I have both Sonarr and qBittorrent and need to delay Sonarr a minute or two to allow for qBittorrent to start so I don’t have to go into the Sonarr settings and make it see qBittorrent. Currently Sonarr starts looks for qBittorrent or it’s service, doesn’t find it and say no download client found. This is because Sonarr starts prior to QBT starting.
Manjaro KDE Testing
~ inxi -Fxxxza ✔
Kernel: 5.15.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=0e474eb0-4b46-41af-8757-51221e62c250 rw rootflags=subvol=@
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2423 date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB
bogomips: 86257
Speed: 2052 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2052 2: 2109 3: 2195 4: 2194 5: 2056 6: 2196 7: 2187 8: 2192 9: 3592
10: 2209 11: 2054 12: 2196
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com.
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:2187 class-ID: 0300
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.4x11.1")
s-diag: 727mm (28.6")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97
size: 673x284mm (26.5x11.2") diag: 730mm (28.8")
OpenGL: renderer: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.15.1-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.39 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 20.82 TiB used: 11.26 TiB (54.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Seagate
model: XPG GAMMIX S11 Pro size: 476.94 GiB block-size: physical: 512 B
rev: 32B3T8EB temp: 33.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Patriot model: Viper M.2 VPN100
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM22.6
temp: 29.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: ST8000AS0002-1NA17Z size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5980 serial: <filter> scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: ST330006 51NS size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 7101 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: Expansion HDD size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1801 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate
model: ST3000DM 001-1E6166 size: 2.73 TiB block-size: physical: 4096 B
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: PNY model: USB 3.0 FD
size: 115.38 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 89.11 GiB (18.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 80.7 MiB (15.8%) priority: -2
file: /swap/swapfile
Message: No sensor data found. Is lm-sensors configured?
Processes: 471 Uptime: 3h 2m wakeups: 37 Memory: 31.33 GiB
used: 8.67 GiB (27.7%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1703 pacman: 1660 lib: 446 flatpak: 32 snap: 11
Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
