How to debug this freeze on resume?
For I while I’ve been struggling with a sporadic freeze on resume. I’ve pursued quite a few suspicions, too many to list here and still have these freezes from time to time.
My current suspicion is that upon resume fangfrisch.service gets sometimes triggered from fangfrisch.timer, but maybe at a time when none of the severs can be reached. And that sometimes might happen when the filesystem is not yet ready to log the tons of errors that get spewed into the log.
I know this sounds far-fetched, but that’s just because I’ve already looked at so many other more plausible explanations.
I could, of course, disable fangfrisch.timer and see if it still happens, but since it’s sporadic, I was hoping for a better idea.
You should provide some context to your words.
You appear to talk about some anti virus … thing.
Seems so:
pamac search -a fangfrisch
python-fangfrisch  1.9.0-4        AUR
    Freshclam like utility that allows downloading unofficial virus definition files
… What is this needed for? Are you dealing with Windows users as recipients? (It should really be up to them to deal with virus scanners, etc.).
Please indicate which OS and DE you are using.
Or, better still, please provide detailed system information:
inxi --admin --verbosity=8 --filter --no-host --width
The output of this command will help others to see factors that might be contributing.
[]$ pamac search fangfrisch --aur
A reminder that packages installed from the AUR remain technically unsupported on Manjaro (or Arch).
A possibility is that a scheduled virus definition update is missed while in a hibernation state, and upon resume is automatically triggered.
This might be consistent with the freeze you describe.
Some perhaps poorly written scripts could for example force maximum bandwidth, thereby limiting availability of resources for other tasks; the result of which might be observed as a temporary freeze; though this might only last as long as the definition update.
This is only speculation.
Antivirus is (arguably) not of great importance in Linux when firewalls and other security measures are in place.
That said, if you feel you must use Antivirus in Manjaro, I might suggest using one of the commercial alternatives designed for Linux, with a guaranteed support path.
Good luck.
As @soundofthunder said; more system info please. For example, do you have any swap defined? (Essential for hibernate, for example). We don’t currently know this.
As a starting point, after posting the already-requested info, we might be able to help further with the results of:
cat /etc/default/grub
and
cat /etc/fstab
… also, blkid may be helpful, too.
:wink:
  Kernel: 6.6.54-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=477c07a4-431c-49c7-90ee-31aa9350aa89 rw rootflags=subvol=@ quiet
    efi=runtime nvme_core.default_ps_max_latency_us=0
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
    wm: kwin_x11 tools: avail: xss-lock vt: 2 dm: 1: LightDM v: 1.32.0
    note: stopped 2: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 21BVCTO1WW v: ThinkPad T16 Gen 1
  Mobo: LENOVO model: 21BVCTO1WW v: SDK0T76463 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21BV_BU_Think_FM_ThinkPad
    T16 Gen 1 uuid: <superuser required> UEFI: LENOVO v: N3MET20W (1.19 )
    date: 04/30/2024
  ID-1: BAT0 charge: 84.3 Wh (97.0%) condition: 86.9/86.0 Wh (101.0%)
    volts: 16.6 min: 15.5 model: Sunwoda 5B10W51873 type: Li-poly
    serial: <filter> status: not charging cycles: 105
  System RAM: total: 48 GiB available: 46.72 GiB used: 7.94 GiB (17.0%)
  Array-1: capacity: 256 GiB slots: 8 modules: 2 EC: None
  Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 16 GiB
    speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: SK Hynix part-no: HMAB2GS6CMR6N-XN serial: N/A
  Device-2: Controller0-ChannelB-DIMM0 type: no module installed
  Device-3: Controller0-ChannelC-DIMM0 type: no module installed
  Device-4: Controller0-ChannelD-DIMM0 type: no module installed
  Device-5: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 32 GiB speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: 16ATF4G64HZ-3G2B4 serial: <filter>
  Device-6: Controller1-ChannelB-DIMM0 type: no module installed
  Device-7: Controller1-ChannelC-DIMM0 type: no module installed
  Device-8: Controller1-ChannelD-DIMM0 type: no module installed
  Info: model: 12th Gen Intel Core i5-1245U bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x434
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
    st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
    KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4400:3300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59916
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow
    tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme
    vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
    xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
    s-diag: 599mm (23.57")
  Monitor-1: eDP-1 model: BOE Display 0x0a30 built: 2021 res: 1920x1200
    hz: 60 dpi: 141 gamma: 1.2 chroma: red: x: 0.635 y: 0.329 green: x: 0.302
    y: 0.608 blue: x: 0.149 y: 0.067 white: x: 0.329 y: 0.337
    size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
    modes: 1920x1200
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46a8 memory: 22.81 GiB unified: yes
  API: Vulkan v: 1.3.295 layers: 4 device: 0 type: integrated-gpu name: Intel
    Graphics (ADL GT2) driver: mesa intel v: 24.2.4-arch1.0.1
    device-ID: 8086:46a8 surfaces: xcb,xlib
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.6.54-2-MANJARO status: kernel-api with: aoss
  Server-2: EsounD v: 0.2.41 status: off tools: esdcat,esdctl,esddsp
  Server-3: NAS v: 1.9.4 status: off tools: auctl,auinfo
  Server-4: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  IF-ID-1: br-02f519f38200 state: down mac: <filter>
  IF-ID-2: br-48c0040987a1 state: down mac: <filter>
  IF-ID-3: br-8e0e69574768 state: down mac: <filter>
  IF-ID-4: br-a1ddc2cf5fed state: down mac: <filter>
  IF-ID-5: docker0 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:10 chip-ID: 8087:0033
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 1.86 TiB used: 1.08 TiB (58.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM790 2TB
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 11296 temp: 55.9 C scheme: GPT
  ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 1.08 TiB (58.1%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 477c07a4-431c-49c7-90ee-31aa9350aa89
    used: 660 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: D942-2969
  ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
    used: 1.08 TiB (58.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 477c07a4-431c-49c7-90ee-31aa9350aa89
  ID-4: /home/<filter>/myStuff raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
  ID-5: /mnt/forBackup raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
  ID-6: /swap raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
  ID-1: swap-1 type: file size: 80 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
  Hub-4: 3-7:7 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 3-7.3:9 info: Noll LLC EcoSteno
    type: keyboard,HID,abstract (modem),CDC-data
    driver: cdc_acm,hid-generic,usbhid interfaces: 5 rev: 2.0
    chip-ID: feed:3621 class-ID: 0a00
  Device-2: 3-7.4:11 info: Hoksi DURGOD Taurus K310 Nebula type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 2f68:0041 class-ID: 0300
  Device-3: 3-8:8 info: Alcor Micro AU9540 Smartcard Reader type: smart card
    mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
  Device-4: 3-10:10 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-2:2 info: Realtek Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 1878
  Packages: 4187 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
    pkgs: 263 libs: 63 pm: pacman pkgs: 3918 libs: 683
    tools: octopi,pacaur,pamac,yay pm: flatpak pkgs: 6
    1: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    2: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    3: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    4: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    7: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    8: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    9: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    10: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    11: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    12: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    13: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    14: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    15: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    16: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    17: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    18: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    19: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    20: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    21: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    22: https://manjaro.ynh.ovh/stable/$repo/$arch
    23: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    25: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    26: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    27: https://mirrors2.manjaro.org/stable/$repo/$arch
    28: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    29: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    30: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    31: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    32: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    33: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    34: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    35: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    36: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    37: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    39: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    40: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    41: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    42: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    43: https://mirror.23m.com/manjaro/stable/$repo/$arch
    44: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    45: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    46: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    47: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    49: http://manjaro.grena.ge/stable/$repo/$arch
    50: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    51: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    52: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    53: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    54: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    55: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    56: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    57: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    58: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    59: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    60: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    61: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    62: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    63: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    64: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    65: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    66: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    67: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    68: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    69: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    70: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    71: https://mirror.init7.net/manjaro/stable/$repo/$arch
    72: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    73: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    74: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    75: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    76: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    77: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    78: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    79: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    80: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    81: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    82: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    83: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    84: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    85: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    86: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    87: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    88: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    89: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    90: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    91: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    92: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    93: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    94: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    95: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    96: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    97: https://manjaro.kurdy.org/stable/$repo/$arch
    98: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    99: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    100: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    101: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    102: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    103: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    104: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    105: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    106: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    107: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    108: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    109: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    110: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    111: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    112: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    113: https://linorg.usp.br/manjaro/stable/$repo/$arch
    114: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    115: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    116: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 354
  1: cpu: 16.3% command: firefox pid: 2226 mem: 709.7 MiB (1.4%)
  2: cpu: 13.1% command: kwin_x11 pid: 1796 mem: 215.4 MiB (0.4%)
  3: cpu: 11.1% command: electron pid: 3238 mem: 303.4 MiB (0.6%)
  4: cpu: 9.8% command: Xorg pid: 1105 mem: 148.5 MiB (0.3%)
  5: cpu: 8.5% command: plasmashell pid: 1864 mem: 428.9 MiB (0.8%)
  Memory top: 5 of 354
  1: mem: 1393.6 MiB (2.9%) command: clamd pid: 941 cpu: 0.6%
  2: mem: 709.7 MiB (1.4%) command: firefox pid: 2226 cpu: 16.3%
  3: mem: 648.7 MiB (1.3%) command: chromium pid: 3794 cpu: 6.2%
  4: mem: 428.9 MiB (0.8%) command: plasmashell pid: 1864 cpu: 8.5%
  5: mem: 427.6 MiB (0.8%) command: java pid: 2245 cpu: 2.3%
  Processes: 354 Power: uptime: 23m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 18.68 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 6 Shell: Zsh v: 5.9
    running-in: kitty inxi: 3.3.36
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT="quiet efi=runtime nvme_core.default_ps_max_latency_us=0"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=false
# Uncomment to enable Hidden Menu, and optionally hide the timeout count
#GRUB_HIDDEN_TIMEOUT=5
#GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_BACKGROUND="/usr/share/grub/background.png"
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
GRUB_DISABLE_OS_PROBER=false
# <file system>                           <mount point>  <type>  <options>  <dump>  <pass>
UUID=D942-2969                            /boot/efi      vfat    defaults,discard,noatime 0       2
UUID=477c07a4-431c-49c7-90ee-31aa9350aa89 /              btrfs   subvol=@,defaults,discard,noatime,space_cache=v2,autodefrag 0       1
UUID=477c07a4-431c-49c7-90ee-31aa9350aa89 /home          btrfs   subvol=@home,defaults,discard,noatime,space_cache=v2,autodefrag 0       2
UUID=477c07a4-431c-49c7-90ee-31aa9350aa89 /home/marko/myStuff          btrfs   subvol=@myStuff,defaults,discard,noatime,space_cache=v2,autodefrag 0       2
UUID=477c07a4-431c-49c7-90ee-31aa9350aa89 /mnt/forBackup          btrfs   defaults,discard,noatime,space_cache=v2,autodefrag 0       2
UUID=477c07a4-431c-49c7-90ee-31aa9350aa89 /swap 	btrfs 	subvol=@swap 0 0
/swap/swapfile 				none 		swap 	sw 0 0
In journalctl -b -1 with a good suspend/resume I get many lines that are missing from the unsuccessful resume.
Nov 04 16:12:11 allofthis kernel: PM: suspend entry (deep)
Nov 04 16:12:15 allofthis kernel: Filesystems sync: 3.674 seconds
Nov 04 16:12:15 allofthis kernel: Freezing user space processes
Nov 05 07:34:47 allofthis kernel: Freezing user space processes completed (elapsed 0.002 seconds)
Nov 05 07:34:47 allofthis kernel: OOM killer disabled.
Nov 05 07:34:47 allofthis kernel: Freezing remaining freezable tasks
Nov 05 07:34:47 allofthis kernel: Freezing remaining freezable tasks completed (elapsed 0.002 seconds)
Nov 05 07:34:47 allofthis kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Nov 05 07:34:47 allofthis kernel: e1000e: EEE TX LPI TIMER: 00000011
Nov 05 07:34:47 allofthis kernel: ACPI: EC: interrupt blocked
Nov 05 07:34:47 allofthis kernel: ACPI: PM: Preparing to enter system sleep state S3
Nov 05 07:34:47 allofthis kernel: ACPI: EC: event blocked
Nov 05 07:34:47 allofthis kernel: ACPI: EC: EC stopped
Nov 05 07:34:47 allofthis kernel: ACPI: PM: Saving platform NVS memory
Nov 05 07:34:47 allofthis kernel: Disabling non-boot CPUs ...
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 1 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 2 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 3 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 4 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 5 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 6 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 7 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 8 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 9 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 10 is now offline
Nov 05 07:34:47 allofthis kernel: smpboot: CPU 11 is now offline
Nov 05 07:34:47 allofthis kernel: ACPI: PM: Low-level resume complete
Nov 05 07:34:47 allofthis kernel: ACPI: EC: EC started
Nov 05 07:34:47 allofthis kernel: ACPI: PM: Restoring platform NVS memory
Nov 05 07:34:47 allofthis kernel: Enabling non-boot CPUs ...
with unsuccessful resume I only have the Nov 04 16:12:11 allofthis kernel: PM: suspend entry (deep) type of entry as the last entry in the journal.
I have never seen efi=runtime before - interesting …
but:
you don’t have any resume file or partition defined
on hibernation, RAM is written to swap and later restored from it
With ext4 this doesn’t work automatically.
I don’t think this is too different with BTRFS - but I don’t know.
I do not think that this is affecting me here since the system is only doing suspend-to-ram.
You are right - I don’t know how I came to assume this was about hibernation when that was not stated.
Sorry!
The last update that I did at first did not go through because it identified a conflict between tlp and power-profiles-daemon. It was the first time I saw that. Could that have been the cause of the resume failure? I have now removed power-profiles-daemon.
Possibly. Both applications are mutually incompatible.
From a recent post by @cscs:-
Just to update this thread: it happened again. So, this was not the remedy.
