I’m running Manjaro ARM 21.08 Vim2 image on a Tv box with meson-gxbb-p201.dtb. As far as I know ,there are two issues with my box:
1. Leds not defined.
ls /sys/class/leds/
Permissions Size User Date Modified Name
lrwxrwxrwx 0 root 7 9月 11:17 input0::capslock -> ../../devices/platform/soc/c9000000.usb/usb1/1-1/1-1:1.0/0003:1C4F:0002.0001/input/input0/input0::capslock
lrwxrwxrwx 0 root 7 9月 11:17 input0::numlock -> ../../devices/platform/soc/c9000000.usb/usb1/1-1/1-1:1.0/0003:1C4F:0002.0001/input/input0/input0::numlock
lrwxrwxrwx 0 root 7 9月 11:17 input0::scrolllock -> ../../devices/platform/soc/c9000000.usb/usb1/1-1/1-1:1.0/0003:1C4F:0002.0001/input/input0/input0::scrolllock
My box has 3 leds which could be switched between green and red :
Led 1 : Green when power on and red when power off
Led 2 : Blink red when receives an ir code and off in the rest time
Led 3 : Green when connected to internet and red otherwise
The output above apparently only found my leds from keyboard. From the vendor’s android dtb file, I found the related definition :
ledlight {
compatible = "amlogic, ledlight";
dev_name = "ledlight";
status = "okay";
power_gpio_0 = < 0x60 >;
net_gpio_0 = < 0x61 >;
gpio_rg {
led_name = "power_led";
led_gpio = < 0x5f 0x0d 0x00 >;
led_active = < 0x01 >;
led_type = "R&G";
linux,phandle = < 0x60 >;
phandle = < 0x60 >;
gpio_r {
led_name = "net_led";
led_gpio = < 0x1c 0x5b 0x00 >;
led_type = "R&G";
linux,phandle = < 0x61 >;
phandle = < 0x61 >;
I’m awared that I’m supposed to define these leds in meson-gxbb-p201.dtb to make kernel find them . But I could not found a detailed tutorial. How could I apply this change to my existing dtb ?
2. Could not poweroff (reboot instead)
In another post ,I thought it could be related to bootloader but it seems to be dtb matter instead .
From vendor’s android dtb :
aml_restart {
compatible = "aml, restart";
sys_reset = < 0x84000009 >;
sys_poweroff = < 0x84000008 >;
While in meson-gxbb-p201.dtb, I did not see similar code .
Any suggestions would be greatly appreciated , thank for this brilliant community ![]()
- The vendor’s android dtb file : (already converted to dts )
R3300M_DTB_Extracted_From_Vendor's_Android - Pastebin.com - meson-gxbb-p201.dtb file :
meson-gxbb-p201.dtb_from_manjaro-arm-21.08 - Pastebin.com
