How to create wifi hotspot for my phone on KDE
on windows 10 there is hotspot and when you turn it on you can connect your phone. But on Manjaro I don’t know if there is a similar feature, because my home wifi is quite weak I want to use the computer’s ethernet as a hotspot like on windows 10.
Hi @SmileGame,
Please see
Note: I’ve never done this and AFAIK your Wifi card must support the feature.
Hope this helps!
Not work :frowning:
Perhaps you Wifi adapter doesn’t have the feature. I honestly have no idea.
:man_shrugging:
As I mentioned, I’ve never done it.
With this you can create a hotspot like you do in Windows 10.
when you create the hotspot, you also have to select on which Band/channel the hotspot should operate, otherwise you’ll see just the wlan, but cannot connect.
