How to create USB bootable disks?
Hi guys, i´m trying to create a USB bootable disk to install Ubuntu server in another pc but i cant find the utility that i always use…Suse create disks or something like that…it cames with Manjaro but it seem was removed on some update…Can anyone help me??? Thanks by the way…I´m using Manjaro Gnome
Try with “multiwriter”. (gnome-multi-writer)
Hi!
There are some of them, personally I use ventoy, also you have etcher or even you can flash the iso with de dd command
Ventoy
Etcher
Both apps are in the repos
You can always use the command line…
It’s still in the repository. It’s called imagewriter. :wink:
Thanks…thats the way i always use… :rofl: :rofl:
