Hi I have a linux manjaro with XFCE on my laptop. The notebook has two disks - SSD and HDD. The system is installed on an SSD. Now I want to create a second HDD for data (music, movies, clauds, etc.). I found the GParted program in the tools. I created the disc in the program. Now located in / run / media / mkey / hdd2 /
Now I want the drive to connect automatically when the system is plugged in. It is best to keep the disc in the home folder. How to do this? Thank you.
<UUID> – this is UUID for partition which you want mount, in your case you can find it with sudo blkid | grep sda2
<mountpoint> – this is path where you want mount this partition, your probably will be something like: /home/mkey/data – this is example mount partition in mkey home in data folder.
