System information
$ inxi -v7azy
Kernel: 5.19.17-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=1aecdb71-bf95-4e25-853c-c709ad46ad6e rw quiet apparmor=1
security=apparmor resume=UUID=71ed32d9-8db4-4067-9ff8-756e4193cd36
udev.log_priority=3
Desktop: Cinnamon v: 5.6.6 tk: GTK v: 3.24.36 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F61c date: 05/10/2021
RAM: total: 30.74 GiB used: 6.86 GiB (22.3%)
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 2770 high: 4163 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3047 2: 4163
3: 3562 4: 3691 5: 1400 6: 1400 7: 2660 8: 3711 9: 3313 10: 1400 11: 3416
12: 1400 13: 2853 14: 1400 15: 3394 16: 3520 bogomips: 121408
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 empty: DVI-D-1
bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 34.0 C
Display: x11 server: X.Org v: 21.1.6 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: BenQ GC2870 serial: <filter>
built: 2018 res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2
size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k5.19.17-2-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-3be1eef3477b state: down mac: <filter>
IF-ID-2: br-b8442be99997 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-3: docker0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-4: veth1e29b2a state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth650e9dd state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: vetha5735fa state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: virbr0 state: down mac: <filter>
all]
IF-ID-8: vnet0 state: down mac: <filter>
all]
Local Storage: total: 99.14 TiB used: 87.2 TiB (88.0%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211210WD temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST16000NM001G-2KK103
size: 14.55 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SB30 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST16000NM001G-2KK103
type: HDD rpm: 7200 serial: <filter> rev: SN03 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MG09ACA18TE
size: 16.37 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0104 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Toshiba model: MG08ACA16TE
type: HDD rpm: 7200 serial: <filter> rev: 4303 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: ST16000NM001G-2KK103
ID-7: /dev/sdf maj-min: 8:80 vendor: Toshiba model: MG08ACA16TE
type: HDD rpm: 7200 serial: <filter> rev: 0102 scheme: GPT
ID-8: /dev/sdg maj-min: 8:96 type: USB vendor: Seagate model: Expansion
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0712
ID-9: /dev/sdh maj-min: 8:112 type: USB vendor: Seagate model: Portable
serial: <filter> rev: 0712 scheme: GPT
ID-1: / raw-size: 914.69 GiB size: 899.26 GiB (98.31%)
used: 539.13 GiB (60.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 1aecdb71-bf95-4e25-853c-c709ad46ad6e
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 374A-28F2
ID-3: /mnt/hdd2 raw-size: 4.55 TiB size: 4.51 TiB (99.19%)
used: 4.06 TiB (90.0%) fs: ext4 dev: /dev/sdh1 maj-min: 8:113 label: T
uuid: d605a480-f133-443c-8fe7-5b0a2d1c60c1
ID-4: /mnt/hdd3 raw-size: 14.55 TiB size: 14.44 TiB (99.20%)
used: 13.49 TiB (93.4%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: V
uuid: 61aea4de-aa02-4f6d-b77d-dc0b09eac2ca
ID-5: /mnt/hdd4 raw-size: 14.55 TiB size: 14.44 TiB (99.20%)
used: 13.49 TiB (93.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: W
uuid: 3e3c48c4-9a6f-4a15-b1e1-b6e61b68e6b2
ID-6: /mnt/hdd5 raw-size: 16.37 TiB size: 16.3 TiB (99.60%)
used: 15.23 TiB (93.4%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: X
uuid: 4e9781ed-4012-4319-a06e-6b0d3070b82e
ID-7: /mnt/hdd6 raw-size: 14.55 TiB size: 14.44 TiB (99.20%)
used: 13.47 TiB (93.3%) fs: ext4 dev: /dev/sde1 maj-min: 8:65 label: U
uuid: 301e3d8d-6c0a-4f7c-864b-4185a70efbb0
ID-8: /mnt/hdd7 raw-size: 14.55 TiB size: 14.44 TiB (99.20%)
used: 13.45 TiB (93.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Z
uuid: d08b13d8-8724-49d5-8000-2fdac4176157
ID-9: /mnt/hdd8 raw-size: 14.55 TiB size: 14.44 TiB (99.20%)
used: 13.49 TiB (93.4%) fs: ext4 dev: /dev/sdf1 maj-min: 8:81 label: Y
uuid: 86b6e5c3-88a3-407b-84ca-71d966e0d0cb
ID-10: /mnt/storage raw-size: N/A size: 93.88 TiB used: 87.2 TiB (92.9%)
fs: fuse.mergerfs source: ERR-102
ID-1: swap-1 type: partition size: 16.52 GiB used: 3.5 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 71ed32d9-8db4-4067-9ff8-756e4193cd36
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: Seagate RSS LLC Portable type: Mass Storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0bc2:2344 class-ID: 0806 serial: <filter>
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-1:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 5-1.1:6 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-2: 5-1.2:7 info: SONiX USB Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 2efd:7812 class-ID: 0301
Hub-7: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 6-1:4 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Device-1: 6-2:2 info: Seagate RSS LLC Expansion type: Mass Storage
chip-ID: 0bc2:2343 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 55.6 C mobo: 31.0 C gpu: amdgpu temp: 36.0 C
Processes: 523 Uptime: 6h 6m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 14.0.6
Packages: pm: pacman pkgs: 2293 libs: 460 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 running-in: tmux: inxi: 3.3.24
I’ve followed the guide Install KVM, QEMU and Virt Manager on Arch Linux / Manjaro
Check hardware support
$ LC_ALL=C lscpu | grep Virtualization
Virtualization: AMD-V
$ egrep -c '(vmx|svm)' /proc/cpuinfo
16
The output must be greater than 0. Otherwise virtualization needs to be enabled in the BIOS.
sudo pacman -Syyu
reboot
sudo pacman -S archlinux-keyring
sudo pacman -S qemu-desktop virt-manager virt-viewer dnsmasq vde2 bridge-utils openbsd-netcat
This gave me some error:
sudo pacman -S ebtables iptables
warning: iptables-1:1.8.8-2 is up to date -- reinstalling
resolving dependencies...
warning: removing 'iptables' from target list because it conflicts with 'iptables-nft'
:: iptables-nft and iptables are in conflict. Remove iptables? [y/N] n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Install libguestfs
sudo pacman -S libguestfs
Start KVM libvirt service
sudo systemctl enable --now libvirtd.service
I got an error
systemctl status libvirtd.service
Unable to open /dev/kvm: No such file or directory
I enabled normal user account to use KVM by modifying /etc/libvirt/libvirtd.conf
and doing
sudo usermod -a -G libvirt $(whoami)
newgrp libvirt
sudo systemctl restart libvirtd.service
Then I launched Virtual Machine Manager and clicked on create new virtual machine and it says:
Warning: KVM is not available. This may mean the KVM package is not installed, or the KVM kernel modules are not loaded. Your virtual machines may perform poorly.
From the KVM ArchWiki page
Arch Linux kernels provide the required kernel modules to support KVM.
- One can check if the necessary modules,
kvm
and eitherkvm_amd
orkvm_intel
, are available in the kernel with the following command:$ zgrep CONFIG_KVM /proc/config.gz
CONFIG_KVM_GUEST=y
CONFIG_KVM_MMIO=y
CONFIG_KVM_ASYNC_PF=y
CONFIG_KVM_VFIO=y
CONFIG_KVM_GENERIC_DIRTYLOG_READ_PROTECT=y
CONFIG_KVM_COMPAT=y
CONFIG_KVM_XFER_TO_GUEST_WORK=y
CONFIG_KVM=m
CONFIG_KVM_INTEL=m
CONFIG_KVM_AMD=m
CONFIG_KVM_AMD_SEV=y
CONFIG_KVM_XEN=y
CONFIG_KVM_EXTERNAL_WRITE_TRACKING=y
The module is available only if it is set to either
y
orm
- Then, ensure that the kernel modules are automatically loaded, with the command:
$ lsmod | grep kvm
kvm 1130496 0
irqbypass 16384 1 kvm
In Fedora you can just install the whole virtualization group with
sudo dnf install @virtualization
Is there a package in the AUR to install and configure all this automatically?
Otherwise, what should I do to solve the KVM is not available
error before I create a new virtual machine?
