Can i create a shortcut for xkill in manjaro?
i used ctrl+esc as a custom shortcut to xkill frozen tasks back in linux mint, can i do so in manjaro? if so then how do i actually do that?
As you mention KDE - I have no idea how KDE works but if I were to set it up I would do the following.
- Ensure you have the xkill app installed
sudo pacman -Syu xorg-xkill - the navigate your settings → my guess is keyboard → hotkeys.
- Then find the desired combo and assign xkill to the combo.
Maybe a mouse gesture? This is an old one I made when I ran Mint.
it has always been ALT-CTRL-ESC
without any modification.
thanks a lot, i didn’t knew that thnx
