Hi
How to contribute code to manjaro packages, for example pamac-tray-icon-plasma ?
Hi
I have imported gitlab repo to my github at
https://github.com/tofi1130/pamac-tray-icon-plasma-up/tree/up
The updated code is at up branch of the above mentioned github repo.
But I don’t know the next steps.
Can you help?
Unfortunately not.
I’m not part of the team, nor do I really know how the gitlab-thingy works. At least not yet. Maybe at some stage. Perhaps. If necessary.
Can you guys help?
Write an issue and link to your repo.
Be prepared though to be ignored.
My suggestion wasn’t really looked at.
It seems that there’s not really any interest in contributions from the community sadly…
It would seem the next step is to make a pull request at gitlab. Why complicate things for yourself by exporting from&&needing to import to gitlab?
@varikonniemi
I read about importing to gitlab on
https://docs.manjaro.org/how-to-send-a-pull-request-to-manjaro-gitlab-from-github/
I don’t know about that
I have the issue on gitlab repo of pamac-tray-icon-plasma
Here it is
Can you tell me if I have taken correct steps in the issue?
