Hey guys, is it possible to connect music player daemon to a local playlist?
Here is how the plugin look in the panel.
And here is “About” page for plugin
What do you mean by local playlist? It is a frontend to mpd, so you should set up your playlist in mpd.
xfce4-mpc-plugin
can be configured to launch a Graphical MPD client
panel-plugins:xfce4-mpc-plugin:start [Xfce Docs]
Right-click panel controls and select Properties
Replace SETME with command to launch an installed MPD GUI client
Clients for the Music Player Daemon | musicpd.org
