My laptop can be connected to my smart tv wirelessly in windows. But I don’t use windows for my daily tasks and I need to use my smart tv as a second monitor. So is there a way to make a connection through wifi in manjaro kde?
Give it a go to gnome network displays. It works just fine on kde plasma. It’s available on aur.
The
gnome-network-displays
throws me these errors:
(gnome-network-displays:33572): Gtk-WARNING **: 19:19:04.833: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
** (gnome-network-displays:33572): WARNING **: 19:19:05.045: Error initing screencast portal: Failed to create portal session (response: 2)
** (gnome-network-displays:33572): WARNING **: 19:19:05.045: Falling back to X11! You need to fix your setup to avoid issues (XDG Portals and/or mutter screencasting support)!
I don’t know what to do now!
They’re warnings. If you’re not running GNOME then falling back to X11 based frame grabbing is expected.
Note that gnome-network-displays
is still experimental. It’s not a finished and polished application and some technical expertise may be required to get it working. See the README.md at GNOME / gnome-network-displays · GitLab
I read the read me but I don’t figure out how to proceed!
If you haven’t read the comments on the AUR page, I suggest taking a look, as there are a few comments that may solve your problem. I looked at both gnome-network-displays and gnome-network-displays-git
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
