How to connect an external monitor while using `video-hybrid-amd-nvidia-prime` drivers?
Description
  • My laptop has integrated AMD GPU and discrete Nvidia GPU, The HDMI port is connected to the Nvidia card, and I want to connect an external monitor using the HDMI cable.
  • my hardware configuration:
  • I don’t know much about drivers in Linux, I just know the basics about Bumblebee and Prime, and Optimus.
  • When I connect the monitor KDE detects it and then the monitor goes into power save mode, I tried to change the primary monitor from KDE Display settings but nothing happened.
Solutions I have Tried
1. X Server Display Configuration
  • I asked GPT3 but I did not find “X Server Display Configuration” section, but I remember that section from my old laptop.
2. prime-run xrandr
prime-run xrandr --output HDMI-1-0 --auto
xrandr: Configure crtc 4 failed
Troubleshooting
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper: RRNotify_OutputChange
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Timestamp:  6975
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Output:  82
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         CRTC:  78
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Mode:  84
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Rotation:  "Rotate_0"
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Connection:  "Connected"
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Subpixel Order:  0
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Output:  507
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         CRTC:  0
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Mode:  0
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Connection:  "Disconnected"
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper: RRScreenChangeNotify
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Config_timestamp:  349702
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Window: 41943045
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Root: 2119
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Size ID: 0
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Size:  1920 1080
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         SizeMM:  508 285
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: XRandROutput 82 update
        m_connected: 0
        m_crtc XRandRCrtc(0x55bf40b22800)
        CRTC: 78
        MODE: 84
        Connection: 0
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Output 82 : connected = true , enabled = true
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: XRandROutput 507 update
        m_connected: 0
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Output 507 : connected = false , enabled = false
        m_connected: 0
        CRTC: 78
        MODE: 84
        Connection: 0
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
Mar 24 18:35:21 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Emitting configChanged()
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: XRandR::setConfig
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Requested screen size is QSize(1920, 1080)
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Needed CRTCs:  1
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Actions to perform:
        Priorities: false
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr:         Change Screen Size: false
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr:         Disable outputs: false
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr:         Change outputs: false
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr:         Enable outputs: false
Mar 24 18:35:22 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: XRandR::setConfig done!
Mar 24 18:35:25 juba-Manjaro wpa_supplicant[875]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-75 noise=9999 txrate=54000
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper: RRNotify_OutputChange
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Timestamp:  6975
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Output:  82
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         CRTC:  78
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Mode:  84
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Rotation:  "Rotate_0"
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Connection:  "Connected"
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Subpixel Order:  0
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Output:  507
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         CRTC:  0
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Mode:  0
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper: RRScreenChangeNotify
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Config_timestamp:  356011
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Window: 41943045
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Root: 2119
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Size ID: 0
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         Size:  1920 1080
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xcb.helper:         SizeMM:  508 285
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: XRandROutput 82 update
        m_connected: 0
        CRTC: 78
        MODE: 84
        Connection: 0
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Output 82 : connected = true , enabled = true
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: XRandROutput 507 update
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 0
Mar 24 18:35:27 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Output 507 : connected = true , enabled = false
        m_connected: 0
        CRTC: 78
        MODE: 84
        Connection: 0
        m_connected: 0
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 0
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Emitting configChanged()
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: XRandR::setConfig
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Requested screen size is QSize(1920, 1080)
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Needed CRTCs:  1
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: Actions to perform:
        Priorities: false
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr:         Change Screen Size: false
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr:         Disable outputs: false
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr:         Change outputs: false
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr:         Enable outputs: false
Mar 24 18:35:28 juba-Manjaro kscreen_backend_launcher[2080]: kscreen.xrandr: XRandR::setConfig done!
Mar 24 18:35:30 juba-Manjaro wpa_supplicant[875]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-73 noise=9999 txrate=54000
Have a look here: Chapter 34. Offloading Graphics Display with RandR 1.4
To use the nvidia’s hdmi, it needs to be loaded as primary driver or with KMS as output sink.
Here is an example when using Nvidia as output sink and amd as output source:
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "AMD Screen"
    Inactive "NVIDIA Screen"
    Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
    Identifier "AMD Navi 21"
    Driver "modesetting"
    BusID "PCI:13:0:0" # hexadecimal: 0d:00.0 -> decimal: 13:00.0
EndSection
Section "Screen"
    Identifier "AMD Screen"
    Device "AMD Navi 21"
EndSection
Section "Device"
    Identifier "NVIDIA GA104"
    Driver "nvidia"
EndSection
Section "Screen"
    Identifier "NVIDIA Screen"
    Device "NVIDIA GA104"
EndSection
In this mode, especially with AMD, you need to load the nvidia driver with KMS:
File: /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="nvidia-drm.modeset=1"
File: /etc/mkinitcpio.conf
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
:notebook: You have to add the values to the variable, not just copy&paste. :wink:
and run:
sudo mkinitcpio -P && sudo update-grub
I’m sorry I don’t understand which values you mean, give me an example please
Hope that is understandable @juba0x00 ?
I understand that these are variables, but I don’t know What should I do, are these values a placeholder or it’s the acutal value, I changed the BusID in xorg.conf, should I change something else?
The variable should already exist in the conf files. You just have to add the values. These are real and not placeholders.
xorg.conf
 cat /etc/X11/xorg.conf         ✔  root@juba-Manjaro
    Identifier "layout"
EndSection
Section "Device"
    BusID "05:00.0"
EndSection
Section "Screen"
EndSection
Section "Device"
    Driver "nvidia"
EndSection
Section "Screen"
EndSection
etc/mkinitcpio.conf
cat /etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(piix ide_disk reiserfs)
# BINARIES
<SNIP>......
  • is there any problem?
    should I restart the laptop now
Should be that way:
BusID "PCI:5:0:0"
But you can try and see if it works your way.
Grub has the correct parameter? If so, then you are good to go.
the GUI did not start, I switched to TTY and undo all the changes to boot the laptop again so I can use the internet.
I think this is the important part of journalctl logs
The logs of Xorg are here: /var/log/
And please don’t post pictures of text. That so unnecessary. Do you know that you can copy and paste the output here? :wink:
I’m sorry, I post a picture to show the colored text so you can read the red text quickly, another reason is that the text is too long to post.
------------ Fri Mar 24 19:23:40 EET 2023 ------------
[  OK  ] Started Show Plymouth Boot Screen.
[  OK  ] Started Forward Password Requests to Plymouth Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Found device SAMSUNG MZVLB256HBHQ-000L2 SYSTEM_DRV.
[  OK  ] Found device SAMSUNG MZVLB256HBHQ-000L2 Windows-SSD.
         Mounting /mnt/Win-SSD...
         Starting File System Check on /dev/disk/by-uuid/A29E-C755...
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Mounted /mnt/Win-SSD.
[  OK  ] Finished File System Check on /dev/disk/by-uuid/A29E-C755.
[  OK  ] Found device WDC_WD10SPSX-08A6W Data.
[  OK  ] Created slice Slice /system/systemd-backlight.
         Mounting /boot/efi...
         Mounting /mnt/Data...
         Starting Load/Save Screen Backlight Brightness of backlight:nvidia_0...
[  OK  ] Mounted /boot/efi.
[  OK  ] Finished Load/Save Screen Backlight Brightness of backlight:nvidia_0.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting Load/Save RF Kill Switch Status...
         Starting Load Kernel Module dm_mod...
         Starting Load Kernel Module loop...
[  OK  ] Finished Load Kernel Module loop.
[  OK  ] Finished Load Kernel Module dm_mod.
         Starting Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Finished Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight.
[  OK  ] Mounted /mnt/Data.
[  OK  ] Reached target Local File Systems.
         Starting Tell Plymouth To Write Out Runtime Data...
         Starting Set Up Additional Binary Formats...
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Set Up Additional Binary Formats.
[  OK  ] Finished Tell Plymouth To Write Out Runtime Data.
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Reached target System Initialization.
[  OK  ] Started CUPS Scheduler.
[  OK  ] Started lenovo-fancurve-restart.path.
[  OK  ] Started Refresh existing P…f archlinux-keyring regularly.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily man-db regeneration.
[  OK  ] Started Monthly clean packages cache.
[  OK  ] Started Generate mirrorlist weekly.
[  OK  ] Started pkgfile database update timer.
[  OK  ] Started Daily verification of password and group files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Path Units.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on CUPS Scheduler.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Socket activation for snappy daemon...
[  OK  ] Listening on Socket activation for snappy daemon.
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
         Starting Save/Restore Sound Card State...
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Bluetooth service...
[  OK  ] Started Periodic Command Scheduler.
         Starting D-Bus System Message Bus...
         Starting Authorization Manager...
         Starting Snap Daemon...
         Starting User Login Management...
[  OK  ] Finished Save/Restore Sound Card State.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Reached target Sound Card.
         Starting Network Manager...
[  OK  ] Started Bluetooth service.
[  OK  ] Started User Login Management.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Reached target Bluetooth Support.
         Starting Hostname Service...
[  OK  ] Started Authorization Manager.
         Starting Modem Manager...
[  OK  ] Started Network Manager.
[  OK  ] Reached target Network.
[  OK  ] Started auto-cpufreq - Aut…d & power optimizer for Linux.
         Starting CUPS Scheduler...
         Starting Permit User Sessions...
[  OK  ] Started vnStat network traffic monitor.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Hostname Service.
         Starting Network Manager Script Dispatcher Service...
         Starting Hold until boot process finishes up...
         Starting Terminate Plymouth Boot Screen...
[  OK  ] Started Snap Daemon.
[  OK  ] Started Modem Manager.
         Starting Time & Date Service...
[  OK  ] Started Network Manager Script Dispatcher Service.
Mar 24 19:21:26 juba-Manjaro systemd-timesyncd[703]: Contacted time server 162.159.200.1:123 (2.manjaro.pool.ntp.org).
Mar 24 19:21:26 juba-Manjaro systemd-timesyncd[703]: Initial clock synchronization to Fri 2023-03-24 19:21:27.235451 EET.
Mar 24 19:22:49 juba-Manjaro wpa_supplicant[876]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-65 noise=9999 txrate=18000
Mar 24 19:22:52 juba-Manjaro wpa_supplicant[876]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-66 noise=9999 txrate=18000
Mar 24 19:23:07 juba-Manjaro wpa_supplicant[876]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=18000
Mar 24 19:23:16 juba-Manjaro systemd[1]: Started Getty on tty2.
Mar 24 19:23:16 juba-Manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:16 juba-Manjaro kernel: audit: type=1130 audit(1679678596.374:153): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:19 juba-Manjaro systemd-logind[715]: The system will reboot now!
Mar 24 19:23:19 juba-Manjaro systemd-logind[715]: System is rebooting.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopping Session 1 of User juba...
Mar 24 19:23:19 juba-Manjaro su[1448]: pam_unix(su:session): session closed for user root
Mar 24 19:23:19 juba-Manjaro audit[1448]: USER_END pid=1448 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:19 juba-Manjaro audit[1448]: CRED_DISP pid=1448 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:19 juba-Manjaro audit[1246]: CRED_DISP pid=1246 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="juba" exe="/usr/bin/login" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:19 juba-Manjaro login[1246]: pam_unix(login:session): session closed for user juba
Mar 24 19:23:19 juba-Manjaro kernel: audit: type=1106 audit(1679678599.870:154): pid=1448 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_close grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:19 juba-Manjaro kernel: audit: type=1104 audit(1679678599.870:155): pid=1448 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_rootok acct="root" exe="/usr/bin/su" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:19 juba-Manjaro kernel: audit: type=1104 audit(1679678599.870:156): pid=1246 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="juba" exe="/usr/bin/login" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:19 juba-Manjaro audit[1246]: USER_END pid=1246 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="juba" exe="/usr/bin/login" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:19 juba-Manjaro kernel: audit: type=1106 audit(1679678599.873:157): pid=1246 uid=0 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="juba" exe="/usr/bin/login" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:19 juba-Manjaro systemd[1]: Removed slice Slice /system/modprobe.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped target Bluetooth Support.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped target Graphical Interface.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped target Multi-User System.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped target Login Prompts.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped target Sound Card.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped target Timer Units.
Mar 24 19:23:19 juba-Manjaro systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Mar 24 19:23:19 juba-Manjaro systemd[1]: logrotate.timer: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped Daily rotation of log files.
Mar 24 19:23:19 juba-Manjaro systemd[1]: man-db.timer: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped Daily man-db regeneration.
Mar 24 19:23:19 juba-Manjaro systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped Monthly clean packages cache.
Mar 24 19:23:19 juba-Manjaro systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped Generate mirrorlist weekly.
Mar 24 19:23:19 juba-Manjaro systemd[1]: pkgfile-update.timer: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped pkgfile database update timer.
Mar 24 19:23:19 juba-Manjaro systemd[1]: shadow.timer: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped Daily verification of password and group files.
Mar 24 19:23:19 juba-Manjaro systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopped target System Time Set.
Mar 24 19:23:19 juba-Manjaro systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Closed LVM2 poll daemon socket.
Mar 24 19:23:19 juba-Manjaro systemd[1]: systemd-coredump.socket: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Closed Process Core Dump Socket.
Mar 24 19:23:19 juba-Manjaro systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Mar 24 19:23:19 juba-Manjaro systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mar 24 19:23:19 juba-Manjaro ModemManager[770]: <info>  caught signal, shutting down...
Mar 24 19:23:19 juba-Manjaro systemd[1]: Stopping Modem Manager...
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Save/Restore Sound Card State...
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping auto-cpufreq - Automatic CPU speed & power optimizer for Linux...
Mar 24 19:23:20 juba-Manjaro avahi-daemon[709]: Got SIGTERM, quitting.
Mar 24 19:23:20 juba-Manjaro bluetoothd[710]: Terminating
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Mar 24 19:23:20 juba-Manjaro avahi-daemon[709]: Leaving mDNS multicast group on interface wlp4s0.IPv6 with address fdb4:f58e:e06c:5000:479b:8f91:a511:30c8.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Bluetooth service...
Mar 24 19:23:20 juba-Manjaro avahi-daemon[709]: Leaving mDNS multicast group on interface wlp4s0.IPv4 with address 192.168.1.3.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Periodic Command Scheduler...
Mar 24 19:23:20 juba-Manjaro avahi-daemon[709]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping CUPS Scheduler...
Mar 24 19:23:20 juba-Manjaro avahi-daemon[709]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Getty on tty2...
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Getty on tty3...
Mar 24 19:23:20 juba-Manjaro bluetoothd[710]: Stopping SDP server
Mar 24 19:23:20 juba-Manjaro bluetoothd[710]: Exit
Mar 24 19:23:20 juba-Manjaro systemd[1]: Starting Generate shutdown-ramfs...
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Simple Desktop Display Manager...
Mar 24 19:23:20 juba-Manjaro sddm[827]: Signal received: SIGTERM
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Load/Save Random Seed...
Mar 24 19:23:20 juba-Manjaro vnstatd[792]: Info: SIGTERM received, exiting.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping vnStat network traffic monitor...
Mar 24 19:23:20 juba-Manjaro systemd[1]: bluetooth.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.0246] modem-manager: ModemManager no longer available
Mar 24 19:23:20 juba-Manjaro ModemManager[770]: <info>  ModemManager is shut down
Mar 24 19:23:20 juba-Manjaro crond[711]: (CRON) INFO (Shutting down)
Mar 24 19:23:20 juba-Manjaro avahi-daemon[709]: avahi-daemon 0.8 exiting.
Mar 24 19:23:20 juba-Manjaro mkinitcpio[2315]: ==> Starting build: none
Mar 24 19:23:20 juba-Manjaro mkinitcpio[2315]:   -> Running build hook: [sd-shutdown]
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Bluetooth service.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: avahi-daemon.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro kernel: audit: type=1131 audit(1679678600.060:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: cronie.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro kernel: audit: type=1131 audit(1679678600.097:159): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Periodic Command Scheduler.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: ModemManager.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro kernel: audit: type=1131 audit(1679678600.127:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Modem Manager.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: auto-cpufreq.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro kernel: audit: type=1131 audit(1679678600.170:161): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro mkinitcpio[2315]: ==> Build complete.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped auto-cpufreq - Automatic CPU speed & power optimizer for Linux.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=auto-cpufreq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: auto-cpufreq.service: Consumed 3.812s CPU time.
Mar 24 19:23:20 juba-Manjaro systemd[1]: cups.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro kernel: audit: type=1131 audit(1679678600.213:162): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=auto-cpufreq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped CUPS Scheduler.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: vnstat.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped vnStat network traffic monitor.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=vnstat comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: sddm.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Simple Desktop Display Manager.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: getty@tty3.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Getty on tty3.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=getty@tty3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: getty@tty2.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Getty on tty2.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: alsa-restore.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Save/Restore Sound Card State.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Finished Generate shutdown-ramfs.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: systemd-random-seed.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Load/Save Random Seed.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd-logind[715]: Session 1 logged out. Waiting for processes to exit.
Mar 24 19:23:20 juba-Manjaro audit: BPF prog-id=36 op=UNLOAD
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.4687] device (wlp4s0): state change: activated -> deactivating (reason 'connection-removed', sys-iface-state: 'managed')
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.4689] manager: NetworkManager state is now DISCONNECTING
Mar 24 19:23:20 juba-Manjaro dbus-daemon[712]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=735 comm="/usr/bin/NetworkManager --no-daemon")
Mar 24 19:23:20 juba-Manjaro systemd[1]: Removed slice Slice /system/getty.
Mar 24 19:23:20 juba-Manjaro systemd[1]: plymouth-quit-wait.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Hold until boot process finishes up.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=plymouth-quit-wait comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: plymouth-quit.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Terminate Plymouth Boot Screen.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=plymouth-quit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: Starting Show Plymouth Reboot Screen...
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopping Authorization Manager...
Mar 24 19:23:20 juba-Manjaro dbus-daemon[712]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Received SIGRTMIN+20 from PID 2446 (plymouthd).
Mar 24 19:23:20 juba-Manjaro kernel: wlp4s0: deauthenticating from b4:f5:8e:e0:6c:58 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 24 19:23:20 juba-Manjaro systemd[1]: Started Show Plymouth Reboot Screen.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=plymouth-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: polkit.service: Deactivated successfully.
Mar 24 19:23:20 juba-Manjaro systemd[1]: Stopped Authorization Manager.
Mar 24 19:23:20 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:20 juba-Manjaro systemd[1]: Tell Plymouth To Jump To initramfs was skipped because of an unmet condition check (ConditionPathExists=/run/initramfs/bin/sh).
Mar 24 19:23:20 juba-Manjaro wpa_supplicant[876]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=b4:f5:8e:e0:6c:58 reason=3 locally_generated=1
Mar 24 19:23:20 juba-Manjaro wpa_supplicant[876]: wlp4s0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.6981] device (wlp4s0): supplicant interface state: completed -> disconnected
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.6982] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.6984] device (wlp4s0): state change: deactivating -> disconnected (reason 'connection-removed', sys-iface-state: 'managed')
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7139] dhcp4 (wlp4s0): canceled DHCP transaction
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7140] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7140] dhcp4 (wlp4s0): state changed no lease
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7143] dhcp6 (wlp4s0): canceled DHCP transaction
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7143] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7144] dhcp6 (wlp4s0): state changed no lease
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7341] device (wlp4s0): set-hw-addr: set MAC address to 9E:8D:B3:46:EF:42 (scanning)
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7749] manager: NetworkManager state is now DISCONNECTED
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7755] device (wlp4s0): supplicant interface state: disconnected -> interface_disabled
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7755] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> interface_disabled
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7755] device (wlp4s0): supplicant interface state: interface_disabled -> disconnected
Mar 24 19:23:20 juba-Manjaro NetworkManager[735]: <info>  [1679678600.7755] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> disconnected
Mar 24 19:23:21 juba-Manjaro sudo[1427]: pam_unix(sudo:session): session closed for user root
Mar 24 19:23:21 juba-Manjaro audit[1427]: USER_END pid=1427 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:21 juba-Manjaro audit[1427]: CRED_DISP pid=1427 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:21 juba-Manjaro systemd[1]: session-1.scope: Deactivated successfully.
Mar 24 19:23:21 juba-Manjaro kernel: kauditd_printk_skb: 14 callbacks suppressed
Mar 24 19:23:21 juba-Manjaro kernel: audit: type=1106 audit(1679678601.873:177): pid=1427 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:21 juba-Manjaro kernel: audit: type=1104 audit(1679678601.873:178): pid=1427 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=juba-Manjaro addr=? terminal=/dev/tty3 res=success'
Mar 24 19:23:21 juba-Manjaro systemd[1]: Stopped Session 1 of User juba.
Mar 24 19:23:21 juba-Manjaro systemd[1]: session-1.scope: Consumed 6.061s CPU time.
Mar 24 19:23:21 juba-Manjaro systemd[1]: Stopping User Login Management...
Mar 24 19:23:21 juba-Manjaro systemd[1]: Stopping User Manager for UID 1000...
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Activating special unit Exit the Session...
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Stopped target Main User Target.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Stopped target Basic System.
Mar 24 19:23:21 juba-Manjaro systemd-logind[715]: Removed session 1.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Stopped target Paths.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Stopped target Sockets.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Stopped target Timers.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed D-Bus User Message Bus Socket.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed GnuPG network certificate management daemon.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed GnuPG cryptographic agent and passphrase cache.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed p11-kit server.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed PipeWire Multimedia System Socket.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Closed Sound System.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Removed slice User Application Slice.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Reached target Shutdown.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Finished Exit the Session.
Mar 24 19:23:21 juba-Manjaro systemd[1378]: Reached target Exit the Session.
Mar 24 19:23:21 juba-Manjaro (sd-pam)[1379]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[juba] ruser=[<unknown>] rhost=[<unknown>]
Mar 24 19:23:21 juba-Manjaro systemd[1]: user@1000.service: Deactivated successfully.
Mar 24 19:23:21 juba-Manjaro systemd[1]: Stopped User Manager for UID 1000.
Mar 24 19:23:21 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:21 juba-Manjaro kernel: audit: type=1131 audit(1679678601.956:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro systemd[1]: systemd-logind.service: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped User Login Management.
Mar 24 19:23:22 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro kernel: audit: type=1131 audit(1679678602.083:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro audit: BPF prog-id=30 op=UNLOAD
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopping Permit User Sessions...
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopping User Runtime Directory /run/user/1000...
Mar 24 19:23:22 juba-Manjaro kernel: audit: type=1334 audit(1679678602.103:181): prog-id=30 op=UNLOAD
Mar 24 19:23:22 juba-Manjaro systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped Permit User Sessions.
Mar 24 19:23:22 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro systemd[1]: run-user-1000.mount: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro kernel: audit: type=1131 audit(1679678602.136:182): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro systemd[1]: Unmounted /run/user/1000.
Mar 24 19:23:22 juba-Manjaro systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped User Runtime Directory /run/user/1000.
Mar 24 19:23:22 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro kernel: audit: type=1131 audit(1679678602.196:183): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro systemd[1]: Removed slice User Slice of UID 1000.
Mar 24 19:23:22 juba-Manjaro systemd[1]: user-1000.slice: Consumed 6.216s CPU time.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Network.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Remote File Systems.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopping Network Manager...
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopping WPA supplicant...
Mar 24 19:23:22 juba-Manjaro NetworkManager[735]: <info>  [1679678602.2178] caught SIGTERM, shutting down normally.
Mar 24 19:23:22 juba-Manjaro wpa_supplicant[876]: p2p-dev-wlp4s0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 24 19:23:22 juba-Manjaro wpa_supplicant[876]: nl80211: deinit ifname=p2p-dev-wlp4s0 disabled_11b_rates=0
Mar 24 19:23:22 juba-Manjaro wpa_supplicant[876]: p2p-dev-wlp4s0: CTRL-EVENT-TERMINATING
Mar 24 19:23:22 juba-Manjaro wpa_supplicant[876]: wlp4s0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 24 19:23:22 juba-Manjaro NetworkManager[735]: <info>  [1679678602.2942] device (wlp4s0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Mar 24 19:23:22 juba-Manjaro wpa_supplicant[876]: nl80211: deinit ifname=wlp4s0 disabled_11b_rates=0
Mar 24 19:23:22 juba-Manjaro wpa_supplicant[876]: wlp4s0: CTRL-EVENT-TERMINATING
Mar 24 19:23:22 juba-Manjaro NetworkManager[735]: <info>  [1679678602.3494] device (wlp4s0): set-hw-addr: reset MAC address to C4:23:60:8C:B4:64 (unmanage)
Mar 24 19:23:22 juba-Manjaro systemd[1]: wpa_supplicant.service: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped WPA supplicant.
Mar 24 19:23:22 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro kernel: audit: type=1131 audit(1679678602.386:184): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro kernel: ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
Mar 24 19:23:22 juba-Manjaro NetworkManager[735]: <info>  [1679678602.6220] device (p2p-dev-wlp4s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mar 24 19:23:22 juba-Manjaro dbus-daemon[712]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=735 comm="/usr/bin/NetworkManager --no-daemon")
Mar 24 19:23:22 juba-Manjaro dbus-daemon[712]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Mar 24 19:23:22 juba-Manjaro NetworkManager[735]: <info>  [1679678602.6597] exiting (success)
Mar 24 19:23:22 juba-Manjaro systemd[1]: NetworkManager.service: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped Network Manager.
Mar 24 19:23:22 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopping D-Bus System Message Bus...
Mar 24 19:23:22 juba-Manjaro kernel: audit: type=1131 audit(1679678602.733:185): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro systemd[1]: dbus.service: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped D-Bus System Message Bus.
Mar 24 19:23:22 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Basic System.
Mar 24 19:23:22 juba-Manjaro systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Path Units.
Mar 24 19:23:22 juba-Manjaro systemd[1]: cups.path: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped CUPS Scheduler.
Mar 24 19:23:22 juba-Manjaro systemd[1]: lenovo-fancurve-restart.path: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro kernel: audit: type=1131 audit(1679678602.793:186): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped lenovo-fancurve-restart.path.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Slice Units.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Removed slice User and Session Slice.
Mar 24 19:23:22 juba-Manjaro systemd[1]: user.slice: Consumed 6.216s CPU time.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Socket Units.
Mar 24 19:23:22 juba-Manjaro systemd[1]: avahi-daemon.socket: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Mar 24 19:23:22 juba-Manjaro systemd[1]: cups.socket: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Closed CUPS Scheduler.
Mar 24 19:23:22 juba-Manjaro systemd[1]: dbus.socket: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Closed D-Bus System Message Bus Socket.
Mar 24 19:23:22 juba-Manjaro systemd[1]: snapd.socket: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Closed Socket activation for snappy daemon.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target System Initialization.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Local Encrypted Volumes.
Mar 24 19:23:22 juba-Manjaro systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Local Integrity Protected Volumes.
Mar 24 19:23:22 juba-Manjaro systemd[1]: Stopped target Local Verity Protected Volumes.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1...
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:nvidia_0...
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopping Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight...
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopping Set Up Additional Binary Formats...
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-sysctl.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Apply Kernel Variables.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-modules-load.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Load Kernel Modules.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopping Network Time Synchronization...
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Mar 24 19:23:23 juba-Manjaro systemd[1]: run-credentials-systemd\x2dsysctl.service.mount: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro audit[2461]: SYSTEM_SHUTDOWN pid=2461 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounted /run/credentials/systemd-sysctl.service.
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Network Time Synchronization.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-backlight@backlight:amdgpu_bl1.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:amdgpu_bl1.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-backlight@backlight:amdgpu_bl1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-backlight@backlight:nvidia_0.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-backlight@backlight:nvidia_0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:nvidia_0.
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-backlight@leds:platform::kbd_backlight.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-backlight@leds:platform::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-binfmt.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Set Up Additional Binary Formats.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro audit: BPF prog-id=29 op=UNLOAD
Mar 24 19:23:23 juba-Manjaro systemd[1]: Removed slice Slice /system/systemd-backlight.
Mar 24 19:23:23 juba-Manjaro systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Mar 24 19:23:23 juba-Manjaro systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Create Volatile Files and Directories.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped target Local File Systems.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped target Mounted snaps.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped target Mounting snaps.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounting /boot/efi...
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounting /mnt/Data...
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounting /mnt/Win-SSD...
Mar 24 19:23:23 juba-Manjaro ntfs-3g[684]: Unmounting /dev/sda2 (Data)
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup.service...
Mar 24 19:23:23 juba-Manjaro ntfs-3g[509]: Unmounting /dev/nvme0n1p3 (Windows-SSD)
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounting /run/credentials/systemd-tmpfiles-setup-dev.service...
Mar 24 19:23:23 juba-Manjaro umount[2472]: umount: /run/credentials/systemd-tmpfiles-setup.service: no mount point specified.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounting Temporary Directory /tmp...
Mar 24 19:23:23 juba-Manjaro systemd[1]: mnt-Data.mount: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounted /mnt/Data.
Mar 24 19:23:23 juba-Manjaro systemd[1]: boot-efi.mount: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounted /boot/efi.
Mar 24 19:23:23 juba-Manjaro systemd[1]: mnt-Win\x2dSSD.mount: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounted /mnt/Win-SSD.
Mar 24 19:23:23 juba-Manjaro systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Mount process exited, code=exited, status=32/n/a
Mar 24 19:23:23 juba-Manjaro systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Failed with result 'exit-code'.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounted /run/credentials/systemd-tmpfiles-setup.service.
Mar 24 19:23:23 juba-Manjaro systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup\x2ddev.service.mount: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounted /run/credentials/systemd-tmpfiles-setup-dev.service.
Mar 24 19:23:23 juba-Manjaro systemd[1]: tmp.mount: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Unmounted Temporary Directory /tmp.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped target Swaps.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Reached target Unmount All Filesystems.
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-fsck@dev-disk-by\x2duuid-A29E\x2dC755.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped File System Check on /dev/disk/by-uuid/A29E-C755.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-A29E\x2dC755 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: Removed slice Slice /system/systemd-fsck.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped target Preparation for Local File Systems.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Remount Root and Kernel File Systems.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 24 19:23:23 juba-Manjaro systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Mar 24 19:23:23 juba-Manjaro systemd[1]: Stopped Create Static Device Nodes in /dev.
Mar 24 19:23:23 juba-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sorry, both outputs are useless. Is there no Xorg.0.log ? Does plasma the same thing as gnome now, so logging xorg in the journal? Sorry, but I don’t use plasma and will never.
We need the xorg log.
cat /var/log/Xorg.0.log                                               ✔  root@juba-Manjaro
[     6.609] (--) Log file renamed from "/var/log/Xorg.pid-871.log" to "/var/log/Xorg.0.log"
[     6.611]
X.Org X Server 1.21.1.7
[     6.611] Current Operating System: Linux juba-Manjaro 6.1.20-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Mar 17 19:11:15 UTC 2023 x86_64
[     6.611] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=8b37ea05-3c60-4efd-bc6d-ae41c02a9515 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[     6.611]
[     6.611] Current version of pixman: 0.42.2
[     6.611]    Before reporting problems, check http://wiki.x.org
[     6.611] Markers: (--) probed, (**) from config file, (==) default setting,
[     6.611] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Mar 24 19:32:09 2023
[     6.612] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     6.612] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     6.613] (==) ServerLayout "layout"
[     6.613] (==) No screen section available. Using defaults.
[     6.613] (**) |-->Screen "Default Screen Section" (0)
[     6.613] (**) |   |-->Monitor "<default monitor>"
[     6.613] (==) No monitor specified for screen "Default Screen Section".
[     6.613] (==) Automatically adding devices
[     6.613] (==) Automatically enabling devices
[     6.613] (==) Automatically adding GPU devices
[     6.613] (==) Automatically binding GPU devices
[     6.613] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     6.614] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     6.614]    Entry deleted from font path.
[     6.614] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     6.614] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     6.614] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     6.614] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     6.614] (==) ModulePath set to "/usr/lib/xorg/modules"
[     6.614] (II) The server relies on udev to provide the list of input devices.
[     6.614] (II) Module ABI versions:
[     6.614]    X.Org ANSI C Emulation: 0.4
[     6.614]    X.Org Video Driver: 25.2
[     6.614]    X.Org XInput driver : 24.4
[     6.614]    X.Org Server Extension : 10.0
[     6.615] (++) using VT number 1
[     6.615] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     6.615] (II) xfree86: Adding drm device (/dev/dri/card1)
[     6.615] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card1
[     6.615] (II) xfree86: Adding drm device (/dev/dri/card0)
[     6.615] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.0/drm/card0
[     6.632] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     6.632] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     6.633] (--) PCI: (1@0:0:0) 10de:1f95:17aa:3a3e rev 161, Mem @ 0xd0000000/16777216, 0xfcc0000000/268435456, 0xfcd0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[     6.633] (--) PCI:*(5@0:0:0) 1002:1636:17aa:3a3e rev 199, Mem @ 0xfce0000000/268435456, 0xfcf0000000/2097152, 0xd1500000/524288, I/O @ 0x00001000/256
[     6.633] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     6.633] (II) LoadModule: "glx"
[     6.635] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     6.639] (II) Module glx: vendor="X.Org Foundation"
[     6.639]    compiled for 1.21.1.7, module version = 1.0.0
[     6.639]    ABI class: X.Org Server Extension, version 10.0
[     6.639] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[     6.639]    loading driver: amdgpu
[     6.639] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[     6.639]    loading driver: nvidia
[     6.672] (==) Matched amdgpu as autoconfigured driver 0
[     6.672] (==) Matched ati as autoconfigured driver 1
[     6.672] (==) Matched nvidia as autoconfigured driver 2
[     6.672] (==) Matched nouveau as autoconfigured driver 3
[     6.672] (==) Matched nv as autoconfigured driver 4
[     6.672] (==) Matched modesetting as autoconfigured driver 5
[     6.672] (==) Matched fbdev as autoconfigured driver 6
[     6.672] (==) Matched vesa as autoconfigured driver 7
[     6.672] (==) Assigned the driver to the xf86ConfigLayout
[     6.672] (II) LoadModule: "amdgpu"
[     6.672] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     6.674] (II) Module amdgpu: vendor="X.Org Foundation"
[     6.674]    compiled for 1.21.1.7, module version = 23.0.0
[     6.674]    Module class: X.Org Video Driver
[     6.674]    ABI class: X.Org Video Driver, version 25.2
[     6.674] (II) LoadModule: "ati"
[     6.674] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     6.674] (II) Module ati: vendor="X.Org Foundation"
[     6.674]    compiled for 1.21.1.4, module version = 19.1.0
[     6.688] (II) LoadModule: "nvidia"
[     6.688] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     6.691] (II) Module nvidia: vendor="NVIDIA Corporation"
[     6.691]    compiled for 1.6.99.901, module version = 1.0.0
[     6.691]    Module class: X.Org Video Driver
[     6.692] (II) LoadModule: "nouveau"
[     6.692] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[     6.693] (II) Module nouveau: vendor="X.Org Foundation"
[     6.693]    compiled for 1.21.1.1, module version = 1.0.17
[     6.693]    Module class: X.Org Video Driver
[     6.693]    ABI class: X.Org Video Driver, version 25.2
[     6.693] (II) LoadModule: "nv"
[     6.693] (WW) Warning, couldn't open module nv
[     6.693] (EE) Failed to load module "nv" (module does not exist, 0)
[     6.693] (II) LoadModule: "modesetting"
[     6.693] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     6.694] (II) Module modesetting: vendor="X.Org Foundation"
[     6.694]    compiled for 1.21.1.7, module version = 1.21.1
[     6.694]    Module class: X.Org Video Driver
[     6.694]    ABI class: X.Org Video Driver, version 25.2
[     6.694] (II) LoadModule: "fbdev"
[     6.694] (WW) Warning, couldn't open module fbdev
[     6.694] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     6.694] (II) LoadModule: "vesa"
[     6.694] (WW) Warning, couldn't open module vesa
[     6.694] (EE) Failed to load module "vesa" (module does not exist, 0)
[     6.694] (II) AMDGPU: Driver for AMD Radeon:
        All GPUs supported by the amdgpu kernel driver
[     6.694] (II) NVIDIA dlloader X Driver  525.89.02  Wed Feb  1 23:14:37 UTC 2023
[     6.694] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     6.694] (II) NOUVEAU driver
[     6.694] (II) NOUVEAU driver for NVIDIA chipset families :
[     6.694]    RIVA TNT            (NV04)
[     6.694]    RIVA TNT2           (NV05)
[     6.694]    GeForce 256         (NV10)
[     6.694]    GeForce 2           (NV11, NV15)
[     6.694]    GeForce 4MX         (NV17, NV18)
[     6.694]    GeForce 3           (NV20)
[     6.694]    GeForce 4Ti         (NV25, NV28)
[     6.694]    GeForce FX          (NV3x)
[     6.694]    GeForce 6           (NV4x)
[     6.694]    GeForce 7           (G7x)
[     6.694]    GeForce 8           (G8x)
[     6.694]    GeForce 9           (G9x)
[     6.694]    GeForce GTX 2xx/3xx (GT2xx)
[     6.694]    GeForce GTX 4xx/5xx (GFxxx)
[     6.694]    GeForce GTX 6xx/7xx (GKxxx)
[     6.694]    GeForce GTX 9xx     (GMxxx)
[     6.694]    GeForce GTX 10xx    (GPxxx)
[     6.694] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     6.697] (WW) Falling back to old probe method for modesetting
[     6.697] (II) Loading sub module "fb"
[     6.697] (II) LoadModule: "fb"
[     6.697] (II) Module "fb" already built-in
[     6.697] (II) Loading sub module "wfb"
[     6.697] (II) LoadModule: "wfb"
[     6.697] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     6.698] (II) Module wfb: vendor="X.Org Foundation"
[     6.698]    compiled for 1.21.1.7, module version = 1.0.0
[     6.698]    ABI class: X.Org ANSI C Emulation, version 0.4
[     6.698] (II) Loading sub module "ramdac"
[     6.698] (II) LoadModule: "ramdac"
[     6.698] (II) Module "ramdac" already built-in
[     6.698] (II) AMDGPU(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[     6.698] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     6.698] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     6.698] (==) AMDGPU(0): Default visual is TrueColor
[     6.698] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card0
[     6.698] (==) AMDGPU(0): RGB weight 888
[     6.698] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     6.698] (--) AMDGPU(0): Chipset: "AMD Radeon Graphics" (ChipID = 0x1636)
[     6.698] (II) Loading sub module "fb"
[     6.698] (II) LoadModule: "fb"
[     6.698] (II) Module "fb" already built-in
[     6.698] (II) Loading sub module "dri2"
[     6.698] (II) LoadModule: "dri2"
[     6.698] (II) Module "dri2" already built-in
[     6.820] (II) Loading sub module "glamoregl"
[     6.820] (II) LoadModule: "glamoregl"
[     6.820] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     6.824] (II) Module glamoregl: vendor="X.Org Foundation"
[     6.825]    compiled for 1.21.1.7, module version = 1.0.1
[     6.825]    ABI class: X.Org ANSI C Emulation, version 0.4
[     7.783] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon Graphics (renoir, LLVM 15.0.7, DRM 3.49, 6.1.20-1-MANJARO)
[     7.783] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[     7.783] (==) AMDGPU(0): TearFree property default: auto
[     7.783] (==) AMDGPU(0): VariableRefresh: disabled
[     7.783] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[     7.783] (II) AMDGPU(0): KMS Pageflipping: enabled
[     7.785] (II) AMDGPU(0): Output eDP has no monitor section
[     7.790] (II) AMDGPU(0): EDID for output eDP
[     7.790] (II) AMDGPU(0): Manufacturer: BOE  Model: 8e8  Serial#: 0
[     7.790] (II) AMDGPU(0): Year: 2019  Week: 37
[     7.790] (II) AMDGPU(0): EDID Version: 1.4
[     7.790] (II) AMDGPU(0): Digital Display Input
[     7.790] (II) AMDGPU(0): 8 bits per channel
[     7.790] (II) AMDGPU(0): Digital interface is DisplayPort
[     7.790] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[     7.790] (II) AMDGPU(0): Gamma: 2.20
[     7.790] (II) AMDGPU(0): No DPMS capabilities specified
[     7.790] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[     7.790] (II) AMDGPU(0): Default color space is primary color space
[     7.790] (II) AMDGPU(0): First detailed timing is preferred mode
[     7.790] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[     7.790] (II) AMDGPU(0): Display is continuous-frequency
[     7.790] (II) AMDGPU(0): redX: 0.653 redY: 0.329   greenX: 0.298 greenY: 0.605
[     7.790] (II) AMDGPU(0): blueX: 0.150 blueY: 0.061   whiteX: 0.313 whiteY: 0.329
[     7.790] (II) AMDGPU(0): Manufacturer's mask: 0
[     7.790] (II) AMDGPU(0): Supported detailed timing:
[     7.790] (II) AMDGPU(0): clock: 310.5 MHz   Image Size:  344 x 194 mm
[     7.790] (II) AMDGPU(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2200 h_border: 0
[     7.790] (II) AMDGPU(0): v_active: 1080  v_sync: 1083  v_sync_end 1089 v_blanking: 1176 v_border: 0
[     7.790] (II) AMDGPU(0):  BOE CQ
[     7.790] (II) AMDGPU(0):  NV156FHM-NX1
[     7.790] (II) AMDGPU(0): EDID (in hex):
[     7.790] (II) AMDGPU(0):    00ffffffffffff0009e5e80800000000
[     7.790] (II) AMDGPU(0):    251d0104a52213780754a5a7544c9b26
[     7.790] (II) AMDGPU(0):    0f505400000001010101010101010101
[     7.791] (II) AMDGPU(0):    01010101010147798018713860403020
[     7.791] (II) AMDGPU(0):    360058c21000001a0000000000000000
[     7.791] (II) AMDGPU(0):    00000000000000000000000000fe0042
[     7.791] (II) AMDGPU(0):    4f452043510a202020202020000000fe
[     7.791] (II) AMDGPU(0):    004e5631353646484d2d4e58310a00e0
[     7.791] (II) AMDGPU(0): Printing probed modes for output eDP
[     7.791] (II) AMDGPU(0): Modeline "1920x1080"x120.0  310.47  1920 1968 2000 2200  1080 1083 1089 1176 +hsync -vsync (141.1 kHz eP)
[     7.791] (II) AMDGPU(0): Modeline "1680x1050"x120.0  310.47  1680 1968 2000 2200  1050 1083 1089 1176 +hsync -vsync (141.1 kHz e)
[     7.791] (II) AMDGPU(0): Modeline "1280x1024"x120.0  310.47  1280 1968 2000 2200  1024 1083 1089 1176 +hsync -vsync (141.1 kHz e)
[     7.791] (II) AMDGPU(0): Modeline "1440x900"x120.0  310.47  1440 1968 2000 2200  900 1083 1089 1176 +hsync -vsync (141.1 kHz e)
[     7.791] (II) AMDGPU(0): Modeline "1280x800"x120.0  310.47  1280 1968 2000 2200  800 1083 1089 1176 +hsync -vsync (141.1 kHz e)
[     7.791] (II) AMDGPU(0): Modeline "1280x720"x120.0  310.47  1280 1968 2000 2200  720 1083 1089 1176 +hsync -vsync (141.1 kHz e)
[     7.791] (II) AMDGPU(0): Modeline "1024x768"x120.0  310.47  1024 1968 2000 2200  768 1083 1089 1176 +hsync -vsync (141.1 kHz e)
[     7.791] (II) AMDGPU(0): Modeline "800x600"x120.0  310.47  800 1968 2000 2200  600 1083 1089 1176 +hsync -vsync (141.1 kHz e)
[     7.791] (II) AMDGPU(0): Modeline "640x480"x120.0  310.47  640 1968 2000 2200  480 1083 1089 1176 +hsync -vsync (141.1 kHz e)
[     7.791] (II) AMDGPU(0): Output eDP connected
[     7.791] (II) AMDGPU(0): Using exact sizes for initial modes
[     7.791] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[     7.791] (II) AMDGPU(0): mem size init: gart size :2daae5000 vram size: s:1df28000 visible:1df28000
[     7.791] (==) AMDGPU(0): DPI set to (96, 96)
[     7.791] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[     7.791] (II) Loading sub module "ramdac"
[     7.791] (II) LoadModule: "ramdac"
[     7.791] (II) Module "ramdac" already built-in
[     7.791] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[     7.791] (==) NVIDIA(G0): RGB weight 888
[     7.791] (==) NVIDIA(G0): Default visual is TrueColor
[     7.791] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[     7.791] (**) Option "AllowNVIDIAGpuScreens"
[     7.791] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[     7.791] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[     7.791] (**) NVIDIA(G0): Enabling 2D acceleration
[     7.791] (II) Loading sub module "glxserver_nvidia"
[     7.791] (II) LoadModule: "glxserver_nvidia"
[     7.791] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[     7.812] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     7.812]    compiled for 1.6.99.901, module version = 1.0.0
[     7.812]    Module class: X.Org Server Extension
[     7.812] (II) NVIDIA GLX Module  525.89.02  Wed Feb  1 23:13:01 UTC 2023
[     7.813] (II) NVIDIA: The X server supports PRIME Render Offload.
[     7.831] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[     7.831] (--) NVIDIA(0):     DFP-0
[     7.831] (--) NVIDIA(0):     DFP-1
[     7.831] (--) NVIDIA(0):     DFP-2
[     7.831] (--) NVIDIA(0):     DFP-3
[     7.832] (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce GTX 1650 Ti (TU117-A) at PCI:1:0:0
[     7.832] (II) NVIDIA(G0):     (GPU-0)
[     7.832] (--) NVIDIA(G0): Memory: 4194304 kBytes
[     7.832] (--) NVIDIA(G0): VideoBIOS: 90.17.72.00.56
[     7.832] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[     7.832] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     7.832] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[     7.832] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[     7.832] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     7.832] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     7.832] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     7.832] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     7.832] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[     7.832] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[     7.832] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     7.832] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[     7.832] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[     7.836] (II) NVIDIA(G0): Validated MetaModes:
[     7.836] (II) NVIDIA(G0):     "NULL"
[     7.836] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[     7.836] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[     7.836] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[     7.836] (II) UnloadModule: "nouveau"
[     7.836] (II) Unloading nouveau
[     7.836] (II) UnloadModule: "modesetting"
[     7.836] (II) Unloading modesetting
[     7.836] (II) AMDGPU(0): [DRI2] Setup complete
[     7.836] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[     7.836] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[     7.869] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[     7.870] (II) AMDGPU(0): SYNC extension fences enabled
[     7.870] (II) AMDGPU(0): Present extension enabled
[     7.870] (==) AMDGPU(0): DRI3 enabled
[     7.870] (==) AMDGPU(0): Backing store enabled
[     7.870] (II) AMDGPU(0): Direct rendering enabled
[     7.880] (II) AMDGPU(0): Use GLAMOR acceleration.
[     7.880] (II) AMDGPU(0): Acceleration enabled
[     7.880] (==) AMDGPU(0): DPMS enabled
[     7.880] (==) AMDGPU(0): Silken mouse enabled
[     7.880] (II) AMDGPU(0): Set up textured video (glamor)
[     7.889] (WW) AMDGPU(0): Option "HotplugDriver" is not used
[     7.889] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[     7.889] (II) NVIDIA:     access.
[     7.897] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     7.897] (II) NVIDIA(G0):     may not be running or the "AcpidSocketPath" X
[     7.897] (II) NVIDIA(G0):     configuration option may not be set correctly.  When the
[     7.897] (II) NVIDIA(G0):     ACPI event daemon is available, the NVIDIA X driver will
[     7.897] (II) NVIDIA(G0):     try to use it to receive ACPI event notifications.  For
[     7.897] (II) NVIDIA(G0):     details, please see the "ConnectToAcpid" and
[     7.897] (II) NVIDIA(G0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     7.897] (II) NVIDIA(G0):     Config Options in the README.
[     7.912] (II) NVIDIA(G0): Setting mode "NULL"
[     7.923] (==) NVIDIA(G0): Disabling shared memory pixmaps
[     7.923] (==) NVIDIA(G0): Backing store enabled
[     7.923] (==) NVIDIA(G0): Silken mouse enabled
[     7.923] (==) NVIDIA(G0): DPMS enabled
[     7.923] (II) Loading sub module "dri2"
[     7.923] (II) LoadModule: "dri2"
[     7.923] (II) Module "dri2" already built-in
[     7.923] (II) NVIDIA(G0): [DRI2] Setup complete
[     7.923] (II) NVIDIA(G0): [DRI2]   VDPAU driver: nvidia
[     7.923] (II) Initializing extension Generic Event Extension
[     7.924] (II) Initializing extension SHAPE
[     7.924] (II) Initializing extension MIT-SHM
[     7.924] (II) Initializing extension XInputExtension
[     7.924] (II) Initializing extension XTEST
[     7.924] (II) Initializing extension BIG-REQUESTS
[     7.924] (II) Initializing extension SYNC
[     7.924] (II) Initializing extension XKEYBOARD
[     7.924] (II) Initializing extension XC-MISC
[     7.924] (II) Initializing extension SECURITY
[     7.924] (II) Initializing extension XFIXES
[     7.924] (II) Initializing extension RENDER
[     7.924] (II) Initializing extension RANDR
[     7.924] (II) Initializing extension COMPOSITE
[     7.924] (II) Initializing extension DAMAGE
[     7.924] (II) Initializing extension MIT-SCREEN-SAVER
[     7.925] (II) Initializing extension DOUBLE-BUFFER
[     7.925] (II) Initializing extension RECORD
[     7.925] (II) Initializing extension DPMS
[     7.925] (II) Initializing extension Present
[     7.925] (II) Initializing extension DRI3
[     7.925] (II) Initializing extension X-Resource
[     7.925] (II) Initializing extension XVideo
[     7.925] (II) Initializing extension XVideo-MotionCompensation
[     7.925] (II) Initializing extension GLX
[     7.925] (II) Indirect GLX disabled.
[     7.929] (II) AIGLX: Loaded and initialized radeonsi
[     7.929] (II) GLX: Initialized DRI2 GL provider for screen 0
[     7.929] (II) Initializing extension XFree86-VidModeExtension
[     7.929] (II) Initializing extension XFree86-DGA
[     7.929] (II) Initializing extension XFree86-DRI
[     7.929] (II) Initializing extension DRI2
[     7.929] (II) Initializing extension NV-GLX
[     7.929] (II) Initializing extension NV-CONTROL
[     7.930] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[     7.989] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[     7.989] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     7.989] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     7.989] (**) Power Button: Applying InputClass "system-keyboard"
[     7.989] (II) LoadModule: "libinput"
[     7.989] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     7.991] (II) Module libinput: vendor="X.Org Foundation"
[     7.991]    compiled for 1.21.1.3, module version = 1.2.1
[     7.991]    Module class: X.Org XInput Driver
[     7.991]    ABI class: X.Org XInput driver, version 24.4
[     7.991] (II) Using input driver 'libinput' for 'Power Button'
[     7.991] (**) Power Button: always reports core events
[     7.991] (**) Option "Device" "/dev/input/event2"
[     7.994] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     7.994] (II) event2  - Power Button: device is a keyboard
[     7.995] (II) event2  - Power Button: device removed
[     8.047] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[     8.047] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     8.047] (**) Option "xkb_layout" "us"
[     8.047] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     8.047] (II) event2  - Power Button: device is a keyboard
[     8.048] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[     8.048] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     8.048] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     8.048] (**) Video Bus: Applying InputClass "system-keyboard"
[     8.048] (II) Using input driver 'libinput' for 'Video Bus'
[     8.048] (**) Video Bus: always reports core events
[     8.048] (**) Option "Device" "/dev/input/event6"
[     8.048] (II) event6  - Video Bus: is tagged by udev as: Keyboard
[     8.048] (II) event6  - Video Bus: device is a keyboard
[     8.048] (II) event6  - Video Bus: device removed
[     8.113] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input7/event6"
[     8.113] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     8.113] (**) Option "xkb_layout" "us"
[     8.115] (II) event6  - Video Bus: is tagged by udev as: Keyboard
[     8.115] (II) event6  - Video Bus: device is a keyboard
[     8.115] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[     8.115] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     8.115] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     8.115] (**) Video Bus: Applying InputClass "system-keyboard"
[     8.115] (II) Using input driver 'libinput' for 'Video Bus'
[     8.115] (**) Video Bus: always reports core events
[     8.115] (**) Option "Device" "/dev/input/event11"
[     8.116] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[     8.116] (II) event11 - Video Bus: device is a keyboard
[     8.116] (II) event11 - Video Bus: device removed
[     8.153] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0e/LNXVIDEO:01/input/input11/event11"
[     8.153] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[     8.153] (**) Option "xkb_layout" "us"
[     8.154] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[     8.154] (II) event11 - Video Bus: device is a keyboard
[     8.154] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     8.154] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.154] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.154] (**) Power Button: Applying InputClass "system-keyboard"
[     8.154] (II) Using input driver 'libinput' for 'Power Button'
[     8.154] (**) Power Button: always reports core events
[     8.154] (**) Option "Device" "/dev/input/event1"
[     8.155] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.155] (II) event1  - Power Button: device is a keyboard
[     8.155] (II) event1  - Power Button: device removed
[     8.197] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     8.197] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[     8.197] (**) Option "xkb_layout" "us"
[     8.197] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.197] (II) event1  - Power Button: device is a keyboard
[     8.198] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[     8.198] (II) No input driver specified, ignoring this device.
[     8.198] (II) This device may have been added with another device file.
[     8.198] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[     8.198] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[     8.198] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
[     8.199] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
[     8.199] (II) No input driver specified, ignoring this device.
[     8.199] (II) This device may have been added with another device file.
[     8.199] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event12)
[     8.199] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[     8.199] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[     8.199] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[     8.199] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[     8.199] (**) Integrated Camera: Integrated C: always reports core events
[     8.199] (**) Option "Device" "/dev/input/event12"
[     8.200] (II) event12 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[     8.200] (II) event12 - Integrated Camera: Integrated C: device is a keyboard
[     8.200] (II) event12 - Integrated Camera: Integrated C: device removed
[     8.297] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-3/1-3:1.0/input/input14/event12"
[     8.297] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 10)
[     8.297] (**) Option "xkb_layout" "us"
[     8.298] (II) event12 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[     8.298] (II) event12 - Integrated Camera: Integrated C: device is a keyboard
[     8.299] (II) config/udev: Adding input device USB OPTICAL MOUSE  (/dev/input/event4)
[     8.299] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[     8.299] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[     8.299] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[     8.299] (**) USB OPTICAL MOUSE : always reports core events
[     8.299] (**) Option "Device" "/dev/input/event4"
[     8.355] (II) event4  - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[     8.355] (II) event4  - USB OPTICAL MOUSE : device is a pointer
[     8.355] (II) event4  - USB OPTICAL MOUSE : device removed
[     8.387] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-1/3-1.1/3-1.1:1.0/0003:30FA:0400.0001/input/input4/event4"
[     8.387] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE " (type: MOUSE, id 11)
[     8.387] (**) Option "AccelerationScheme" "none"
[     8.387] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[     8.387] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[     8.387] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[     8.445] (II) event4  - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[     8.445] (II) event4  - USB OPTICAL MOUSE : device is a pointer
[     8.445] (II) config/udev: Adding input device USB OPTICAL MOUSE  (/dev/input/mouse0)
[     8.445] (II) No input driver specified, ignoring this device.
[     8.445] (II) This device may have been added with another device file.
[     8.446] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Keyboard (/dev/input/event5)
[     8.446] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "evdev keyboard catchall"
[     8.446] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[     8.446] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[     8.446] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[     8.446] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[     8.446] (**) Option "Device" "/dev/input/event5"
[     8.447] (II) event5  - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[     8.447] (II) event5  - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[     8.447] (II) event5  - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[     8.470] (II) libinput: ITE Tech. Inc. ITE Device(8910) Keyboard: needs a virtual subdevice
[     8.470] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input5/event5"
[     8.471] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: MOUSE, id 12)
[     8.471] (**) Option "AccelerationScheme" "none"
[     8.471] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) selected scheme none/0
[     8.471] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) acceleration factor: 2.000
[     8.471] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) acceleration threshold: 4
[     8.472] (II) event5  - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[     8.472] (II) event5  - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[     8.473] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Wireless Radio Control (/dev/input/event7)
[     8.473] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[     8.473] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[     8.473] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "system-keyboard"
[     8.473] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Wireless Radio Control'
[     8.473] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: always reports core events
[     8.473] (**) Option "Device" "/dev/input/event7"
[     8.474] (II) event7  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[     8.474] (II) event7  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[     8.474] (II) event7  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[     8.530] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input6/event7"
[     8.530] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Wireless Radio Control" (type: KEYBOARD, id 13)
[     8.530] (**) Option "xkb_layout" "us"
[     8.532] (II) event7  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[     8.532] (II) event7  - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[     8.532] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event17)
[     8.532] (II) No input driver specified, ignoring this device.
[     8.532] (II) This device may have been added with another device file.
[     8.532] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event18)
[     8.533] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event19)
[     8.533] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[     8.533] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[     8.533] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[     8.533] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[     8.533] (**) Ideapad extra buttons: always reports core events
[     8.533] (**) Option "Device" "/dev/input/event19"
[     8.533] (II) event19 - Ideapad extra buttons: is tagged by udev as: Keyboard
[     8.533] (II) event19 - Ideapad extra buttons: device is a keyboard
[     8.533] (II) event19 - Ideapad extra buttons: device removed
[     8.587] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input21/event19"
[     8.587] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 14)
[     8.587] (**) Option "xkb_layout" "us"
[     8.588] (II) event19 - Ideapad extra buttons: is tagged by udev as: Keyboard
[     8.588] (II) event19 - Ideapad extra buttons: device is a keyboard
[     8.589] (II) config/udev: Adding input device MSFT0001:00 04F3:3186 Mouse (/dev/input/event8)
[     8.589] (**) MSFT0001:00 04F3:3186 Mouse: Applying InputClass "evdev pointer catchall"
[     8.589] (**) MSFT0001:00 04F3:3186 Mouse: Applying InputClass "libinput pointer catchall"
[     8.589] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3186 Mouse'
[     8.589] (**) MSFT0001:00 04F3:3186 Mouse: always reports core events
[     8.589] (**) Option "Device" "/dev/input/event8"
[     8.590] (II) event8  - MSFT0001:00 04F3:3186 Mouse: is tagged by udev as: Mouse Pointingstick
[     8.590] (II) event8  - MSFT0001:00 04F3:3186 Mouse: device is a pointer
[     8.591] (II) event8  - MSFT0001:00 04F3:3186 Mouse: device removed
[     8.630] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0003/input/input12/event8"
[     8.630] (II) XINPUT: Adding extended input device "MSFT0001:00 04F3:3186 Mouse" (type: MOUSE, id 15)
[     8.631] (**) Option "AccelerationScheme" "none"
[     8.631] (**) MSFT0001:00 04F3:3186 Mouse: (accel) selected scheme none/0
[     8.631] (**) MSFT0001:00 04F3:3186 Mouse: (accel) acceleration factor: 2.000
[     8.631] (**) MSFT0001:00 04F3:3186 Mouse: (accel) acceleration threshold: 4
[     8.632] (II) event8  - MSFT0001:00 04F3:3186 Mouse: is tagged by udev as: Mouse Pointingstick
[     8.632] (II) event8  - MSFT0001:00 04F3:3186 Mouse: device is a pointer
[     8.633] (II) config/udev: Adding input device MSFT0001:00 04F3:3186 Mouse (/dev/input/mouse1)
[     8.633] (II) No input driver specified, ignoring this device.
[     8.633] (II) This device may have been added with another device file.
[     8.633] (II) config/udev: Adding input device MSFT0001:00 04F3:3186 Touchpad (/dev/input/event10)
[     8.633] (**) MSFT0001:00 04F3:3186 Touchpad: Applying InputClass "evdev touchpad catchall"
[     8.633] (**) MSFT0001:00 04F3:3186 Touchpad: Applying InputClass "libinput touchpad catchall"
[     8.633] (**) MSFT0001:00 04F3:3186 Touchpad: Applying InputClass "touchpad"
[     8.633] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3186 Touchpad'
[     8.633] (**) MSFT0001:00 04F3:3186 Touchpad: always reports core events
[     8.633] (**) Option "Device" "/dev/input/event10"
[     8.634] (II) event10 - MSFT0001:00 04F3:3186 Touchpad: is tagged by udev as: Touchpad
[     8.635] (II) event10 - MSFT0001:00 04F3:3186 Touchpad: device is a touchpad
[     8.635] (II) event10 - MSFT0001:00 04F3:3186 Touchpad: device removed
[     8.673] (**) Option "Tapping" "on"
[     8.674] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0003/input/input13/event10"
[     8.674] (II) XINPUT: Adding extended input device "MSFT0001:00 04F3:3186 Touchpad" (type: TOUCHPAD, id 16)
[     8.675] (**) Option "AccelerationScheme" "none"
[     8.675] (**) MSFT0001:00 04F3:3186 Touchpad: (accel) selected scheme none/0
[     8.675] (**) MSFT0001:00 04F3:3186 Touchpad: (accel) acceleration factor: 2.000
[     8.675] (**) MSFT0001:00 04F3:3186 Touchpad: (accel) acceleration threshold: 4
[     8.676] (II) event10 - MSFT0001:00 04F3:3186 Touchpad: is tagged by udev as: Touchpad
[     8.677] (II) event10 - MSFT0001:00 04F3:3186 Touchpad: device is a touchpad
[     8.678] (II) config/udev: Adding input device MSFT0001:00 04F3:3186 Touchpad (/dev/input/mouse2)
[     8.678] (**) MSFT0001:00 04F3:3186 Touchpad: Applying InputClass "touchpad"
[     8.678] (II) Using input driver 'libinput' for 'MSFT0001:00 04F3:3186 Touchpad'
[     8.678] (**) MSFT0001:00 04F3:3186 Touchpad: always reports core events
[     8.678] (**) Option "Device" "/dev/input/mouse2"
[     8.727] (II) mouse2  - not using input device '/dev/input/mouse2'.
[     8.727] (EE) libinput: MSFT0001:00 04F3:3186 Touchpad: Failed to create a device for /dev/input/mouse2
[     8.727] (EE) PreInit returned 2 for "MSFT0001:00 04F3:3186 Touchpad"
[     8.727] (II) UnloadModule: "libinput"
[     8.728] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[     8.728] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     8.728] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     8.728] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     8.728] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     8.728] (**) AT Translated Set 2 keyboard: always reports core events
[     8.728] (**) Option "Device" "/dev/input/event3"
[     8.728] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     8.728] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[     8.729] (II) event3  - AT Translated Set 2 keyboard: device removed
[     8.747] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[     8.747] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 17)
[     8.747] (**) Option "xkb_layout" "us"
[     8.748] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     8.748] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[     8.749] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[     8.749] (II) No input driver specified, ignoring this device.
[     8.749] (II) This device may have been added with another device file.
[     8.772] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "evdev keyboard catchall"
[     8.772] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[     8.772] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[     8.772] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[     8.772] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[     8.772] (**) Option "Device" "/dev/input/event5"
[     8.772] (II) libinput: ITE Tech. Inc. ITE Device(8910) Keyboard: is a virtual subdevice
[     8.772] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0002/input/input5/event5"
[     8.772] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: KEYBOARD, id 18)
[     8.772] (**) Option "xkb_layout" "us"
[    13.798] (II) AMDGPU(0): EDID vendor "BOE", prod id 2280
[    13.798] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    13.798] (II) AMDGPU(0): Modeline "1920x1080"x0.0  310.47  1920 1968 2000 2200  1080 1083 1089 1176 +hsync -vsync (141.1 kHz eP)
[    13.800] (II) AMDGPU(0): EDID vendor "BOE", prod id 2280
[    13.800] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    13.800] (II) AMDGPU(0): Modeline "1920x1080"x0.0  310.47  1920 1968 2000 2200  1080 1083 1089 1176 +hsync -vsync (141.1 kHz eP)
[    13.801] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    13.801] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[    13.801] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[    13.801] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    13.801] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    13.801] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    13.801] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    13.801] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    13.801] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    13.801] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    13.801] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[    13.801] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[    14.339] (II) AMDGPU(0): EDID vendor "BOE", prod id 2280
[    14.339] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    14.339] (II) AMDGPU(0): Modeline "1920x1080"x0.0  310.47  1920 1968 2000 2200  1080 1083 1089 1176 +hsync -vsync (141.1 kHz eP)
[    14.341] (II) AMDGPU(0): EDID vendor "BOE", prod id 2280
[    14.341] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    14.341] (II) AMDGPU(0): Modeline "1920x1080"x0.0  310.47  1920 1968 2000 2200  1080 1083 1089 1176 +hsync -vsync (141.1 kHz eP)
[    14.341] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    14.341] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[    14.341] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[    14.341] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    14.341] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    14.341] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    14.341] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    14.341] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    14.341] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    14.341] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    14.341] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[    14.341] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[   803.035] (II) config/udev: Adding input device C-Media Electronics Inc.       USB PnP Sound Device (/dev/input/event20)
[   803.035] (**) C-Media Electronics Inc.       USB PnP Sound Device: Applying InputClass "evdev keyboard catchall"
[   803.035] (**) C-Media Electronics Inc.       USB PnP Sound Device: Applying InputClass "libinput keyboard catchall"
[   803.035] (**) C-Media Electronics Inc.       USB PnP Sound Device: Applying InputClass "system-keyboard"
[   803.035] (II) Using input driver 'libinput' for 'C-Media Electronics Inc.       USB PnP Sound Device'
[   803.035] (**) C-Media Electronics Inc.       USB PnP Sound Device: always reports core events
[   803.035] (**) Option "Device" "/dev/input/event20"
[   803.036] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: is tagged by udev as: Keyboard
[   803.036] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: device is a keyboard
[   803.036] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: device removed
[   803.070] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-2/1-2:1.3/0003:8086:0808.0004/input/input22/event20"
[   803.070] (II) XINPUT: Adding extended input device "C-Media Electronics Inc.       USB PnP Sound Device" (type: KEYBOARD, id 19)
[   803.070] (**) Option "xkb_layout" "us"
[   803.073] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: is tagged by udev as: Keyboard
[   803.073] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: device is a keyboard
[   827.630] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: device removed
[   827.660] (II) config/udev: removing device C-Media Electronics Inc.       USB PnP Sound Device
[   827.661] (II) UnloadModule: "libinput"
[   832.656] (II) config/udev: Adding input device C-Media Electronics Inc.       USB PnP Sound Device (/dev/input/event20)
[   832.656] (**) C-Media Electronics Inc.       USB PnP Sound Device: Applying InputClass "evdev keyboard catchall"
[   832.656] (**) C-Media Electronics Inc.       USB PnP Sound Device: Applying InputClass "libinput keyboard catchall"
[   832.656] (**) C-Media Electronics Inc.       USB PnP Sound Device: Applying InputClass "system-keyboard"
[   832.656] (II) Using input driver 'libinput' for 'C-Media Electronics Inc.       USB PnP Sound Device'
[   832.656] (**) C-Media Electronics Inc.       USB PnP Sound Device: always reports core events
[   832.656] (**) Option "Device" "/dev/input/event20"
[   832.658] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: is tagged by udev as: Keyboard
[   832.658] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: device is a keyboard
[   832.658] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: device removed
[   832.720] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-2/1-2:1.3/0003:8086:0808.0005/input/input23/event20"
[   832.720] (II) XINPUT: Adding extended input device "C-Media Electronics Inc.       USB PnP Sound Device" (type: KEYBOARD, id 19)
[   832.720] (**) Option "xkb_layout" "us"
[   832.722] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: is tagged by udev as: Keyboard
[   832.722] (II) event20 - C-Media Electronics Inc.       USB PnP Sound Device: device is a keyboard
This is the working log. The previous one? /var/log/Xorg.1.log
Not found
will optimus manager solve the problem, I’m trying to use it now.
Yes. But it will run nvidia as main as described above. Ok, KMS for nvidia should be considered as experimental, seems it doesn’t work for you.
I’ll try the hybrid mode, Thank you for your help.
Optimus Manager is working very well with hybrid mode.
Thank you @megavolt
