How to configure Whatsdesk (Solved)
Hello there, I’ve been trying Whatsdesk installed via snap store with pretty good results, but when I need to upload a file or use some features, the dialogues open something like this,
I’m Using the Openbox Flavor, Any ideas?
Snaps cause so much problems,try using the AUR version.
pamac install whatsdesk-bin
Way easier than configure some files, Thanks!, it worked!
