Hi, I’m new, I need help !! can you configure a vpn using the cisco any connect client?
thanks and regards
This should help.
https://wiki.archlinux.org/index.php/OpenConnect
If you are using XFCE,
You can go to network settings >> click on the plus in bottom left.
then scroll down in the dropdown and you should have the option.
And that should then open up the window for you where you can set it up and configure.
Thank you very much, I was able to connect, but before I had to update openconnect
Thank you very much for your help
