Hello,
The Grub is in Manjaro, how to configure grub so that when I exit Debian (reboot) it returns me back to Manjaro and not to Debian?.
Thanks for advices
Hello,
Thanks for advices
Hello.
You need to edit the GRUB
file in /etc/default/grub
and configure the GRUB_DEFAULT
to correct option. I think you can check it out on DuckDuckGo.
BR
Hi @Alnone,
As @Quintana said, edit /etc/default/grub
sudo nano /etc/default/grub
And change GRUB_DEFAULT
GRUB_DEFAULT=saved
to:
GRUB_DEFAULT=Manjaro
Save, Ctrl+O, and exit, Ctrl+X nano
Afterwards, you need to update grub.
sudo update-grub
…and then reboot.
Hope it helps!
P.S.:
I am not al all sure if it should be
or
GRUB_DEFAULT=manjaro
So if one doesn’t work, try the other.
I had not found a solution by Google, I never go to a forum without first looking for … anyway, thank you very much.
Mirdarthos, it is correct with capital letters.
Only that when rebooting it went to black screen, but after manual shutdown and several reboots… it hasn’t happened anymore, I also modified: GRUB_TIMEOUT=1
Thank you very much.
