Hello,
I want to update my graphical driver from nouveau to nvidia.
I know my card but can’t find a way to match this information with the 33 Nvidia providers that $ pacman -S nvidia provides.
Any hint what to do? I’ve checked wiki-.archlinux.org-NVIDIA, googled and search this forum but was not able to find what I was looking for.
Thanks
p.s.
this is my first post, please don’t be harsh if I didn’t follow some template for posting question
sudo mhwd -a pci nonfree 0300
inxi -G
You forgot the manjaro wiki
Hi @dyrvenshop, and welcome!
Best would be to use mhwd
. See the wiki:
You can use the Manjaro Hardware Configure tool provided in Manjaro Settings Manager.
FYI, if you have an nvidia card installed, when you install Manjaro, select the non-free driver option when you first run the installer. Saves you all this work later.
