During my research of suspend and hibernation issues, I came across command to check status of powerdevil in Plasma:
michaldybczak Sirius16-Manjaro ~ sudo systemctl --user status plasma-powerdevil.service
Failed to connect to bus: No medium
This was from 2023 on Arch so it couldn’t be that different now in Manjaro, but just to test it out, I tried:
sudo systemctl status plasma-powerdevil.service
Unit plasma-powerdevil.service could not be found.
sudo systemctl status powerdevil
Unit powerdevil.service could not be found.
I do have powerdevil installed:
sudo pacman -Qs powerdevil
local/powerdevil 5.27.10-2 (plasma)
Manages the power consumption settings of a Plasma Shell
Power saving settings in Plasma seems to work fine.
What am I missing?
cscs
2
$ pacman -Ql powerdevil | grep service
powerdevil /usr/lib/systemd/user/plasma-powerdevil.service
powerdevil /usr/share/dbus-1/system-services/
powerdevil /usr/share/dbus-1/system-services/org.kde.powerdevil.backlighthelper.service
powerdevil /usr/share/dbus-1/system-services/org.kde.powerdevil.chargethresholdhelper.service
powerdevil /usr/share/dbus-1/system-services/org.kde.powerdevil.discretegpuhelper.service
$ systemctl --user status plasma-powerdevil
● plasma-powerdevil.service - Powerdevil
Loaded: loaded (/usr/lib/systemd/user/plasma-powerdevil.service; static)
Active: active (running) since Sat 2024-02-17 15:27:41; 9h ago
Main PID: 1543 (org_kde_powerde)
Tasks: 8 (limit: 16547)
Memory: 25.2M (peak: 26.2M)
CPU: 5.657s
CGroup: /user.slice/user-1000.slice/user@1000.service/background.slice/plasma-powerdevil.service
└─1543 /usr/lib/org_kde_powerdevil
LOL, the solution was to NOT USE sudo…
That was a quickie
system
Closed
4
