How to check and fix EXT4 filesystem?
Hello,
Today I was deleting some files from my NVME to increase freespace, but while deleting some of them the system stuck in the Plasma pop-up window for deleting the files but not completing the operation, so when I clicked on cancel, “all files was moved the trash folder” so I empty the trash folder but for my surprise there was no difference in the freespace. I deleted around 30GiB so I had the impression that maybe the filesystem got corrupted somehow and tried to check its integrity and fix issues with the command below:
sudo e2fsck -vf /dev/nvme2n1
Below you can see the result:
e2fsck 1.47.1 (20-May-2024)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open /dev/nvme2n1
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem.  If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
 or
    e2fsck -b 32768 <device>
/dev/nvme2n1 contains `DOS/MBR boot sector; partition 1 : ID=0xee, start-CHS (0x0,0,2), end-CHS (0x3ff,255,63), startsector 1, 3907029167 sectors, extended partition table (last)' data
The command don’t look able to properly fix the issue that was found. I tried some variations as included in -v, but no success. Is there any recommendation?
Note: The NVME assembled in a PCIe Card adapter, and the card is assembled on the motherboard.
System information:
  Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.11-x86_64
    root=UUID=84e0bfca-0d47-4324-b85a-614ea38dc5f9 rw rootflags=subvol=@ quiet
    splash udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
    wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: MACHINIST model: E5-MR9A v: V1.0
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: 5.11 date: 10/25/2022
  System RAM: total: 32 GiB available: 31.19 GiB used: 5.5 GiB (17.6%)
  Array-1: capacity: 256 GiB note: check slots: 4 modules: 4
    EC: Multi-bit ECC max-module-size: 64 GiB note: est.
  Device-1: DIMM_A1 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2400 MT/s volts: curr: 1 min: 1.14 max: 1.26 width (bits): data: 72
    total: 72 manufacturer: Hynix Semiconductor part-no: HMA41GR7AFR4N-UH
    serial: <filter>
  Device-2: DIMM_B1 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Device-3: DIMM_C1 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Device-4: DIMM_D1 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Info: model: Intel Xeon E5-2667 v4 bits: 64 type: MT MCP arch: Broadwell
    level: v3 note: check built: 2015-18 process: Intel 14nm family: 6
    model-id: 0x4F (79) stepping: 1 microcode: 0xB000040
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
    desc: 8x256 KiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 1200 min/max: 1200/3600 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
    7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200 13: 1200 14: 1200
    15: 1200 16: 1200 bogomips: 102220
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts cat_l3 cdp_l3 clflush cmov constant_tsc cpuid
    cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cx16 cx8
    dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_ppin intel_pt
    invpcid lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc
    nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt
    pse pse36 pti pts rdrand rdseed rdt_a rdtscp rep_good rtm sdbg sep smap
    smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
    XT / 5700/5700 XT] vendor: Micro-Star MSI driver: amdgpu v: kernel
    arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
    empty: DP-1,DP-3,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:731f class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 18.1.8 DRM 3.59 6.11.2-4-MANJARO) device-ID: 1002:731f
    memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv v: 24.2.4-arch1.0.1
    device-ID: 1002:731f surfaces: xcb,xlib,wayland
  Device-1: Intel 8 Series/C220 Series High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    bus-ID: 05:00.1 chip-ID: 1002:ab38 class-ID: 0403
  API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.5 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  IF-ID-1: virbr0 state: down mac: <filter>
  Info: services: NetworkManager
  Local Storage: total: 2.73 TiB used: 1.69 TiB (61.9%)
    model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 234100WD temp: 31.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: A-Data model: LEGEND 850 Lite
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: V0922A0 temp: 30.9 C
    scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:2 model: X16 Plus SSD 2TB size: 1.82 TiB
    block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: SN11273 temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
    used: 102.46 GiB (22.0%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:6
    label: N/A uuid: 84e0bfca-0d47-4324-b85a-614ea38dc5f9
    used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5 label: N/A
    uuid: 21D8-DE05
  ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
  ID-4: /home/<filter>/Games raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 142.01 GiB (31.0%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: GAMES uuid: b5780269-0438-4193-9b38-7df4aaf9b229
  ID-5: /home/<filter>/HDD-2TB raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 1.45 TiB (81.1%) fs: ext4 dev: /dev/nvme2n1p1 maj-min: 259:7
    label: NVME-2TB uuid: ec1ddfe0-4768-4618-93f3-bfbbafeb12a4
  ID-6: /swap raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
  ID-7: /var/cache raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
  ID-8: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 512 MiB (100.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
  Device-1: 3-1:2 info: SINO WEALTH Gaming KB type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:002a class-ID: 0300
  Device-2: 3-2:3 info: [Maxxter] USB GAMING MOUSE type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 18f8:0fc0 class-ID: 0301
  Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 26.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
    mem: 38.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 839
  Processes: 358 Power: uptime: 2h 39m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 1553 pm: pacman pkgs: 1503 libs: 452 tools: pamac pm: flatpak
    pkgs: 50 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.36
It appears that the file system that you use is NOT ext4
but BTRFS instead.
It has got it’s own tool set to do these tasks.
(I know literally nothing about it - that’s why I don’t use it)
e2fsck is definitely the wrong thing™, the wrong tool!
Do not force it!
You’ll destroy your system / your data if you do.
ps:
/home/username/Games
and
/home/username/HDD-2TB
are ext4 file systems - but not the rest, not /home itself
You are right here, and I was deleting file only from this NVME that is mounted in this folder. This is for personal files and the only NVME that I do back-up cloning it.
Games NVME is also Ext4 for game performance.
Only root is BTRFS, in order to use snapshots.
You tried to run it on a namespace. You’re meant to run it on a filesystem, so a partition such as nvme2n1p1.
  1. Never run an fsck on a mounted filesystem.
  2. For btrfs, use “btrfs check” — see the man page.
  3. btrfs may need periodic balance’ing to redistribute the extents and free up space. This is due to how btrfs allocates free space. Again, see the man page(s).
I unmount the NVME before running the command.
The interest is only to check and fix EXT4, no BTRFS.
Thank you, that was the reason, So, I was trying to run the command for the full NVME while I should run it for specific partition.
free tip:
sudo tune2fs -m 0 /dev/nvme2n1p1
sudo tune2fs -m 0 /dev/nvme0n1p1
to make quite a few gigabytes more available to you
with ext2/3/4, upon file system creation, 5% are reserved for the root user exclusively
since these two ext4 partitions are pretty large and mounted under /home anyway
root does not need to have spare space there
-m 0 sets the reserved for root space to zero
This command can be done while the file system is mounted.
