All guides wich i found tell about changing swap with systemctl, but manjaro uses systemd and there is no details in archwiki or google wich i found about changing swappines with systemd systems
Any clue how to change swappines on systemd-controles system (exclude changing default 60 in kernel code)
Tomek
23 January 2022 23:07
2
For temporarily change (to 10) you can use:
sysctl -w vm.swappiness=10
To make this change permanent you need create file:
/etc/sysctl.d/99-swappiness.conf
vm.swappiness=10
Here you can find more details.
cscs
23 January 2022 23:32
3
systemctl is, to quote, “Control the systemd system and service manager”, as in very much a part of systemd.
Whereas sysctl is to control kernel parameters.
But the example above of a ‘directory.d’ is a function of systemd … .d folders can contain files that function as drop-in configurations or addendums.
Though I dont think I have seen swappiness managed through systemd/systemctl … except maybe as dynamically set through a service or timer.
ydar
23 January 2022 23:37
4
Google “manjaro swappiness” - the first result gives a solution.
sudo tee /etc/sysctl.d/swappiness.conf <<< vm.swappiness=10
and this to check it is working after restart
inxi -Pa
Documentation for /proc/sys/vm/ - swappiness — The Linux Kernel documentation
Does number in filename matters ?
I tryed same thing in past but used 75 instead of 99, and it ain’t worked
system
Closed
4 February 2022 22:21
7
