Hello guys ignore the music played on my spotify, I would like to leave the style of my window the same as that of windows or mac, I applied a theme but I know that this is not solved with a theme, I would like to make it more beautiful. Do you know how to make them more compact or even inside the app?
Images above
Well, that’s not ugly, so can only be made different.
And I believe what you’re looking for is called “Window decorations” and I believe you can customize it with the Gnome tweaks tool. Although I can’t be absolutely sure, using KDE and all.
To match the style of Windows or Mac on your Manjaro XFCE, focus on the application’s settings. Unfortunately, themes might not cover everything. Explore each app’s settings for customization, and for a more compact look, check if there are options for density or compact mode within the app itself.
