jojo06
5 December 2023 15:32
1
Greetings…
There is a bug in QEMU/kvm virtualization. I want to install windows in QEMU/kvm but it has requirements; it wants tpm. And i cant add it from add hardware from Gui. The error popup occurs “tpm version is not supported”
I learnt we need to replace the lines:
-D TPM_ENABLE in PKGBUILD with:
-D TPM1_ENABLE
-D TPM2_ENABLE
What GUI? virt-manager?
If so, as @Yochanan already pointed out, you probably only need to install swtpm.
It appears others have been able to make it work. See:
https://www.reddit.com/r/archlinux/comments/15mjqap/tpm_version_20_is_not_supported_qemukvm/
Where did you find that information? That build flag is not in the qemu PKGBUILD .
jojo06
5 December 2023 16:16
4
That’s referencing edk2-ovmf, not qemu. Anyway, those flags were added with 202202-2 as noted in the bug report.
system
Closed
7 December 2023 04:36
6
